Author Topic: clutch plates for a 350 four  (Read 570 times)
Offline riccardino
« on: June 22, 2020, 12:40:27 PM »
hi all
will these work as replacement parts for the following ?
22201ML4610 =  22201-302-000 =    (first plate)
https://www.motorcycleproducts.co.uk/136mm-x-3mm-clutch-friction-plate-with-10-pegs/1/006958
22202ML4611 = 22201-333-010 =  (other six)
https://www.motorcycleproducts.co.uk/136mm-x-29mm-clutch-friction-plate-with-10-pegs/1/006957
what does the 2.9mm and 3mm refer to ?
thanks for your help
« Last Edit: June 22, 2020, 12:44:01 PM by riccardino »
2004 Honda CBF 500
1971 Honda CB 500 K0
1974 Honda CB 350 F1
Offline jamesv220820
Re: clutch plates for a 350 four
« Reply #1 on: June 22, 2020, 01:23:15 PM »
Hey your better bet is to go with a company like DSS for $51 USD for the whole set
https://www.davidsilverspares.com/CB350-FOUR/part_2858/
Or if you want OEM you can use CMSL for a higher premium
https://www.cmsnl.com/honda-cb350f-four-1972-usa_model435/partslist/E++09.html#.XvESpJ5Kht9
or if you are feeling like blowing cash ...
There is nothing to fear but fear itself . . . and trying to restore a cb350f
« Reply #2 on: June 22, 2020, 01:39:02 PM »
Lastly always look at brands. You will see EBC (cheapest typically) Vesrah, Barnett, OEM etc. Do some googling . everyone has their own opinion
Offline riccardino
« Reply #3 on: June 22, 2020, 01:41:06 PM »
Hi James
Thanks
but will the plate posted fit ?
2004 Honda CBF 500
