Author Topic: cb400F instruments fitting  (Read 765 times)
Offline timbo
« on: April 18, 2020, 02:30:10 AM »
Hello,
Can sombody point me out where this goes on the instrument fitting? I can find it on the parts manuel but it is not clear where it goes.
Sorry for asking these stupid questions but I thaught I took enough pictures before dissasembly but itseems I forgot to capture some details.
Offline ttr400
    • ttr400 Projects and Billet parts.
Re: cb400F instruments fitting
« Reply #1 on: April 18, 2020, 04:04:36 AM »
It secures the head light/indicator frame to the top triple tree. should be 2 of them.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline timbo
« Reply #2 on: April 18, 2020, 04:21:54 AM »
ok,that makes sense. I was thinking in that direction but was not sure. I do have two of them.
Thanks for the info
Offline timbo
« Reply #3 on: April 18, 2020, 08:49:12 AM »
So they are between the plastic casing and the metal plate where te speedo and tacho are mounted on?
The screws fot the indicator frame go from inside to out than? I am a little confiused because the holes in the plastic frame are threaded.
Offline jakec
« Reply #4 on: April 18, 2020, 09:34:39 AM »
Use the parts diagrams when you get stuck. I do it all the time.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline timbo
« Reply #5 on: April 18, 2020, 09:51:34 AM »
it was not clear to me but I got it. it is for the two bolts that hold al the instruments to the fork.
I wonder why they are not just two normal nuts.
Offline jakec
« Reply #6 on: April 18, 2020, 09:58:15 AM »
I wondered that too when I put them on.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
