Author Topic: Terry's NEW big Kawasaki build, the "Lockdown 1428" special.  (Read 55951 times)
Re: Terry's NEW big Kawasaki build, the "Lockdown 1428" special.
« Reply #450 on: October 05, 2020, 12:22:15 PM »
If I should use an oil cooler, thermostate that does not connect cooler until after 100C.
Condense in engine needs to evaporate. I have seen on my oil tank thermometer that it take a while to reach 100C.
Need of a cooler those few days when temperature pass 110C going to 120C which is the highest seen so far. Ambient temp around 30C.
Better oil withstand higher temp a longer period of time.
Per,What is optimum oil temperature for the best performance on your CB750 ?
I do not know.
I would like to have it between 100-110C.
I have noticed clutch slip if throttling hard,  WOT and quick gear shifts after only 5-10 minutes ride. No problems when warmer.
Condensed water out thru the breather and not too hot. 120C is no problem for synthetic oil, but pressure reduces some. I had a hot summer when I found an oil pressure gauge to be mandatory, temp in oil tank often 120C.
Search on air cooled Porsches forums where oil temp and wear can be found.
Offline grcamna2
« Reply #451 on: October 05, 2020, 01:11:11 PM »
ok
75' CB400F/'bunch o' parts'
Offline scunny
  • don't call me expert
« Reply #452 on: October 05, 2020, 08:19:47 PM »
If it's any help, on my VTR1000, the radiator fans come on at 100c and the bike will shut down I believe at 120c. Never seen it that high.
She runs Castrol semi synthetic.
Back to Terry's Kawi.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #453 on: October 05, 2020, 08:27:07 PM »
No worries Scunny, another issue being discussed on the Z Owners FB page where I posted a pic is the concern that the stock starter motor might not have the grunt to spin my engine. Apparently there’s a Honda starter that can go in with minimal mods, but someone else reckons using bigger diameter power and earth leads will make the bigger starter unnecessary.
It is a bastard to turn over by hand, so I’m gonna see if the starter on my VTR1000R (my spare one) will fit? Worth a look, at least..... ;D
Offline scunny
« Reply #454 on: October 05, 2020, 08:31:17 PM »
Yep, bigger leads (and clean connections) always helps. The current, ie amp draw travels on the circumference of a cable, so, the bigger the diameter, the larger surface area for the current to flow.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #455 on: October 05, 2020, 08:33:44 PM »
Yep, I might chop a foot or two off my jumper leads, and see how that works! ;D
Offline grcamna2
« Reply #456 on: October 05, 2020, 09:05:46 PM »
Terry,Does APE have any leads on a drag race starter,different reduction gears ?
« Reply #457 on: October 05, 2020, 09:34:04 PM »
Thanks Bill, nope, nothing seen so far, and it kind of makes sense, the 1428cc bikes were mostly drag bikes, which would have been started using an external starter. ;D
Offline grcamna2
« Reply #458 on: October 05, 2020, 09:55:43 PM »
Alright Terry,I think it may be something you'll need to fabricate,a special starter of some type.You said someone thinks a certain Honda starter will work(installed into the same place as your oem Kawasaki starter sits ?)in your 1428 engine? I wonder if possibly a CBX starter ? I know you'll find a fix for this, something like Mc'Gyver  :D
« Reply #459 on: October 05, 2020, 10:36:01 PM »
Harley starter?
« Reply #460 on: October 05, 2020, 11:14:55 PM »
Thanks Guys, yep, definitely thought about a Harley starter (or a Triumph Rocket 111 starter) but they're physically too large, so maybe a bigger one off a Jap bike might have to do? Well there's no rush, winter has come back this week after a beautiful weekend, so not fussed. ;D
« Reply #461 on: October 05, 2020, 11:25:26 PM »
Another engine you start with a rope, chainsaw style. That will start the mighty Arias Kawasaki ;D
Offline grcamna2
« Reply #462 on: October 06, 2020, 12:05:42 AM »
How about a custom 25" long kickstart lever ?? !  :D
Offline spotty
« Reply #463 on: October 06, 2020, 02:31:15 AM »
Nah, pushstart only, do it the manly way, electric starters are for girlies
i blame Terry
« Reply #464 on: October 06, 2020, 04:24:40 AM »
Press the button and she starts.... Yeah... feels girly... ;)
« Reply #465 on: October 06, 2020, 04:48:03 AM »
I did think about one of those race bike starters that uses a high power electric motor that you roll your back wheel onto, spin up the back wheel, and dump the clutch? Only problems is if I go for a ride and need to stop somewhere I'll have to build a trailer so I can tow a generator and the starter assembly with me? ;D
« Reply #466 on: October 06, 2020, 07:01:22 AM »
Or an older design. Tool can be used for personal protection too.
Offline grcamna2
« Reply #467 on: October 06, 2020, 10:14:32 AM »
You could stow it under the seat like was on my 78' Z1-R;one solid cast iron lever that wouldn't fold-up.
« Reply #468 on: October 06, 2020, 05:01:03 PM »
Well I love that little Austin 7, my cuz gave the remains of one as a resto project when I was 16, but I gave it back when I joined the Army, but they were a neat little car.
I scored a complete GPZ1100 engine on FB overnight, the seller bought it for a buggy project that never came to pass, and for an extra 50 bucks, he’s dropping it off at my place tomorrow afternoon. I want to pop the cam cover off to confirm I’ve got the cam timing right on the 1428 engine, and if I do have a problem with the big beast down the track, I’ll install the GPZ engine into the bike so I’ve got a rider.
Not as exciting as a 1428 of course, but over 100 BHP in stock guise, it will be a reasonable alternative, and it comes with an oil cooler..... ;D
Offline grcamna2
« Reply #469 on: October 06, 2020, 06:56:49 PM »
That sounds great that you'll have an extra GPZ1100 engine,seeing those at the right time !
Offline spotty
« Reply #470 on: October 06, 2020, 08:14:43 PM »
alternately a GPz1100 powered rideon lawnmower
i blame Terry
« Reply #471 on: October 06, 2020, 09:33:52 PM »
Whatever you  do.. please don't run the oil cooler lines around the side of the engine... it looks so cheap and shortcutty...
 Unless  you can't choose fittings, and use a wrench, and whip up a bracket or two...
« Reply #472 on: October 06, 2020, 10:19:56 PM »
Thanks Guys, should be fun! Interestingly Frank, Kawasaki ran both oil lines over the top of the engine on the GPZ1100 engine, I'm just wondering though whether I should be running some external oil lines to move the oil around the head? If so, I may have to run my lines either side of the engine, but I'll do it as elegantly as is practically possible...... ;D
« Reply #473 on: October 08, 2020, 03:02:59 AM »
So it  was a red letter day today, apart from my K0 frame arriving safe and sound, the GPZ1100 engine was dropped off a little while later, so with some help from my youngest  son, we lumped it up onto the bench with the 1428 and Z1 engines.
1428 GPZ1100 engine 8 Oct 2020 1 by Terry Prendergast, on Flickr
I was madly stripping the K0 frame so didn't have time to touch the GPZ engine, but I did turn the crank to make sure it isn't seized, and all appears good. Tomorrow I'll pop the cam cover off and check the cam timing, just to confirm that I haven't messed anything up with the 1428 engine before I tuck it back into bed in the Z1000 frame. More tomorrow. ;D
1428 GPZ1100 engine 8 Oct 2020 2 by Terry Prendergast, on Flickr
Offline grcamna2
« Reply #474 on: October 08, 2020, 12:05:02 PM »
Terry,You've created a vintage Kawasaki 'Safe Place' for wayward engines that need that special touch.
