Thanks Per, we had a few days where it got pretty hot like that last summer, it's hard to believe that the worst bushfires we've had in Australian history were only 6 months ago when we're all worried about getting Covid-19 now? To quote Bob Dylan, "The times, they are a changing"......
Anyhoo, back to the bike. I double and triple checked my starter farter device, drilled a couple of holes in the sleeve betwixt the crank and the needle roller bearing for the starter clutch gear to allow oil through, loctited the 8mm allen screws that secured the starter clutch to the alloy "flywheel", and loctited the 8mm screw that holds the whole assembly onto the crank, via the internal taper. I installed the alternator cover with a new gasket, and called it good.
There are a couple of 10mm OD knock pins that locate the kick starter cover to the engine case that I couldn't remove from the black engine without mangling them, so I machined up a couple on the lathe. Same/same for the solid 6mm steel locating pins for the ignition cover, then installed all the covers. I couldn't bring myself to re-use the rusty old unbrako's that the PO had used, so ratted thru my stainless steel screw collection (I do have a complete stainless kit for the Z1-B, but didn't want to break into it) and after shortening only a couple of screws, all the covers were on.
1428 Engine build 30 Jun 2020 by
Terry Prendergast, on Flickr
I mentioned earlier that I needed to strip and paint the cam cover. I used paint stripper and a wire brush, in my ultrasonic cleaner @ 50 deg C, mainly because it was bloody cold, and so sticking my hands in 50 deg C water was much nicer than using the garden hose and drenching myself with icy cold water. It'd be awful if I gave myself a cold and got shoved in hospital as a potential CV case. Once I got every little scrap of black paint off I washed it thoroughly, stuck in my industrial oven @ 100 deg C, got it nice and warm and hit it with some etch primer.
1428 Engine build 30 Jun 2020 2 by
Back in the oven for a few more minutes @ 100 deg c again, and the etch primer was dry. Out again, a couple of nice quick coats of VHT engine enamel, and back in the still hot oven (switched off) to dry overnight. Tomorrow I'll crank it back up to 100 deg c for 2 hours as per the instructions to cure properly and become oil and fuel proof, apparently.....
1428 Engine build 30 Jun 2020 1 by
By this time it was dark, freezing cold, and I was half drunk. I decided that I needed to be fully drunk, so went inside. My 91 year old Ma is quite worried about me getting Covid 19 as there's been a spike in the last week or so due to stupid people ignoring the social distancing rules, and she even sent me some paper masks to wear. I didn't like them, so I bought my own, and took a pic to show her. I sent the pic to her via FB messages, and she hasn't responded yet, so I'm guessing I've given her a heart attack and killed her. Ooops...........
Terry's mask 30 Jun 2020 by
