Author Topic: Cb650 Cafe racer  (Read 14400 times)
Offline dkihlgren
Cb650 Cafe racer
« Reply #75 on: July 05, 2020, 02:22:35 AM »
It’s running folks!
Now I’ll have to connect charging from regulator and do some checks. None of that rattling noise is there anymore.
The idle sounds So Smooth and balanced !
Thanks! I’ve spent quite some time on jetting. Followed a good guide. Start with idle adjustment and slow speed jets. Then midrange and last 3/4 to full throttle. Maby dyna ignition helps?
Offline DaveBarbier
Re: Cb650 Cafe racer
« Reply #76 on: July 05, 2020, 04:39:53 AM »
Yeah sounds great! Glad you’re getting the jetting going but normally you want to go mixture screws for idle, main jet, and then work your way down from there. If you go right up the line - mixture screw, slow jet, needle, main - then once you change the main that will alter the ones below it. Main jet affects everything from about 1/4 throttle up. But either way you do it you’ll learn something, haha
Offline dkihlgren
« Reply #77 on: July 05, 2020, 06:46:10 AM »
Well guess I’ll have to redo jetting a bit then.. everything is wired now. To bad we got weather similar to a monsoon now. Does not work well without rear fender. HAHA
Offline dkihlgren
« Reply #78 on: July 05, 2020, 09:49:09 AM »
A small test outside our house. Soon roads are dry.
« Reply #79 on: July 05, 2020, 02:06:23 PM »
Sounds smooth. Enjoy the riding weather!
Offline dkihlgren
« Reply #80 on: July 13, 2020, 10:45:28 AM »
Checked the voltage today. Stable 14.4V at high idle. Have to do some measurment while driving. If it is 14.4 all the time it should be safe for lithium battery?
Offline DaveBarbier
« Reply #81 on: July 14, 2020, 04:39:50 AM »
My shorai’s max is 15.2 but any lithium battery you get will say what the voltage requirements are. I’d bet you’d be fine. Look on their websites though and it will say.
« Reply #82 on: July 14, 2020, 08:38:18 AM »
14.4 should be okay but like Dave suggested, check the battery specs. You have the correct type of reg/rect.
On the flip side, make sure to check your battery especially if you take a long break in riding (or storage). If the voltage drops to a certain threshold, it will not recharge.
Online scottly
« Reply #83 on: July 14, 2020, 09:53:56 PM »
Yes, 14.4V is optimum for LiFePo batteries.
« Reply #84 on: July 15, 2020, 11:13:10 AM »
Thanks for chiming in Scottly.  It's been a while since I ran one.
« Reply #85 on: September 04, 2020, 09:46:53 AM »
Nominated for BOTM. Can I get a "second"?  IF so, please do it in the nomination thread:  http://forums.sohc4.net/index.php/topic,180400.0.html
Offline dkihlgren
« Reply #86 on: September 09, 2020, 01:55:44 PM »
Such a boost that my build is liked I only followed my vision
« Reply #87 on: September 10, 2020, 04:29:32 AM »
I will happily second that nomination!
Offline tshrey
« Reply #88 on: September 11, 2020, 07:58:35 AM »
What did you come up with for a taper angle on the two parts?  I went with a CBR600RR rotor because it is much thinner than the VFR one and thinking since it was a honda they would be the same but the rotor angle was a little larger than the crank taper.
Offline dkihlgren
« Reply #89 on: November 26, 2020, 07:12:18 AM »
I measured it to 5 degrees. But I used a micrometer on my lathe to adjust the taper. Of I would do it again I would go with a cbr rotor. There is very limited space worh the vfr one.
Offline dkihlgren
« Reply #90 on: May 22, 2021, 09:54:45 AM »
Some minor stuff has been done. Got my hands on some fine cb650 custom forks. My old one was leaking. Will shorten them later. Bought emulators from Mikes XS.
Skickat från min iPhone med Tapatalk
Offline Jimcg
« Reply #91 on: May 22, 2021, 10:25:43 AM »
Your 650 looks great! 👍
Do the emulators make a noticeable difference and in what way?
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
Offline dkihlgren
« Reply #92 on: May 24, 2021, 10:34:23 AM »
/Jim
Thanks!
Fork feels a bit mote smooth now. I have not adjusted the emulators and all I hade in my garage was 10W for oil. 15W is recommended.
Offline dkihlgren
« Reply #93 on: June 07, 2021, 06:27:48 AM »
Got some shiny bits today. 18” front and rear. I alteady have a 550 rear hub and in the mail there is a cb750 front hub.
Offline Godffery
  • Godffery's Garage
« Reply #94 on: June 07, 2021, 02:35:00 PM »
*LIKE*
Offline Jimcg
« Reply #95 on: June 10, 2021, 02:46:53 AM »
Looks nice!
That will be very interesteing to see, how a 650 will look with spokes. I bet it will be super!  8)
/Jim
About my bike:
Offline dkihlgren
« Reply #96 on: June 10, 2021, 10:09:32 AM »
Looks nice!
/Jim
I hope so! Will take some time since I got my hands on an incomplete hub. Have to make a few collars, and I’m tripple checking all measurments for the spokes.
Offline grcamna2
« Reply #97 on: July 20, 2021, 10:36:57 PM »
dkihlgren,How are your spoke wheels:coming along?  :)
Offline dkihlgren
« Reply #98 on: July 23, 2021, 01:10:05 AM »
Waiting for parts. Ordered spokes and they were to long. Waiting for a thread rolling head. Shipping is slow these covid-days.
Offline dkihlgren
« Reply #99 on: November 25, 2021, 12:34:42 AM »
Rear wheel in the making. Also bought CBR600RR throttle bodies..Think it will be fun to build a CB650i with a speeduino.
