Author Topic: Cracked rear brake cam pin SOLVED  (Read 673 times)
Offline Dolomite
  • I'm 40% Dolomite.
« on: April 21, 2020, 07:45:21 AM »
Long story short, brake rod snapped the other day. Decided to change pads since I needed to be back there anyway and discovered the rear brake cam pin is cracked/bent. Now I'm having difficulty locating this part, Honda part number is 43141341020. However, I am able to find Honda 43141341000, for the 71-76. Does anyone know if the two parts are swappable? I can't discern any differences in pictures, thanks!
« Last Edit: April 27, 2020, 11:30:03 AM by Dolomite »
Re: Cracked rear brake cam pin
« Reply #1 on: April 21, 2020, 08:36:13 AM »
If its only the last 3 numbers different you should be fine
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #2 on: April 21, 2020, 08:38:50 AM »
I did a little closer looking and the early ones look like they only have a center notch for lubrication while the one that came off mine has a spiral cut along the whole length, so I'm not sure if they will be the same lengthwise. I might just end up buying a used outer drum plate with the cam and arm if I can't find just the cam.
Offline 69cb750
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #4 on: April 21, 2020, 09:59:46 AM »
Those were the ones I looked at but the design is different. Here's a photo of the cam pin that came out sans the end I had to cut off because it was so bent it couldn't slide out of the hub. You can see the spiral cut on it.
« Reply #5 on: April 21, 2020, 10:10:11 AM »
Wow, that's the rustiest one I have ever seen!
I have several brake backing plates for the 71-76 (K1-K6), you could have one for postage if you want it.
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #6 on: April 21, 2020, 10:14:28 AM »
It's not all rust! I think a lot of it is old caked brake dust. I went head and just ordered a rear hub with the pin and lever off Ebay, but I appreciate the offer.
Everytime I try to repair something on this bike, I find something new. At this point I think the only original pieces of the bike are the frame and the triple.
« Reply #7 on: April 21, 2020, 10:20:00 AM »
Ha! Been there, lost count of how many times. :)
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #8 on: April 27, 2020, 11:27:06 AM »
Quick update, got a whole rear assembly off fleabay from a 77 with 16k miles (it was sooooo shiny). Inatalled that, new EBC pads, new rod assembly, new castle nuts with new cotter pins and everything is perfect. Thanks again!
Offline Dolomite
  • I'm 40% Dolomite.
Re: Cracked rear brake cam pin SOLVED
« Reply #9 on: April 27, 2020, 11:31:03 AM »
Oh and here are the two pins side by side. Can you guess which one has 16k miles vs 55k miles?
« Reply #10 on: April 27, 2020, 04:49:19 PM »
On all of my earlier model 750's I have much less threaded rod coming out the backside of the adjuster nut. Maybe its just the way I position the arm on the spindle as the is a notch or two leeway on that.
