Author Topic: Dual Disc Conversion Complete - Still Have Questions!  (Read 5842 times)
Offline Dolomite
  • I'm 40% Dolomite.
Re: Dual Disc Conversion Complete - Still Have Questions!
« Reply #25 on: April 27, 2020, 11:36:03 AM »
+1 to the dotheton write up, that's how I did mine
« Reply #26 on: April 27, 2020, 12:07:33 PM »
Nobody told me, found it at Yamiya and found out how long it was when I got it. Saw that stock should be too short
Adj screw
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_184_86&products_id=941
Spring
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_184_86&products_id=940
I usually going thru everything they have while order.
It can sometimes be a bigger package and bill.
Some parts are cheaper at Yamiya, some parts cost much more than eBay.
Offline jamracing
« Reply #27 on: April 27, 2020, 12:10:24 PM »
I wish i read that dotheton post before doing mine... The three I read didn't mention shaving the fork lugs...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #28 on: April 27, 2020, 02:11:50 PM »
Don’t worry about buying from Yamiya, they do a great job, parts are top quality.
Shipping is very well executed.
Very responsive when there are questions.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #29 on: April 27, 2020, 08:54:44 PM »
You shorten the rear lug, is that correct.
First time I hear about shaving down the lug. Any numbers or pictures? If i shave it down, i'll need to add even more washers to top it from binding, won't it?
Read through this.
https://www.dotheton.com/index.php?threads/single-disk-to-dual-disk-brake-conversion-for-cb750.1525/
I couldn't figure out why you guys are talking about shaving lugs until I saw the author of the DTT link. ::) Anubis, AKA el cheapo, was run off this forum years ago. There is NO shaving of lugs required!!!!
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #30 on: April 27, 2020, 09:25:17 PM »
I slowly filed/sanded the bracket and used shims until I had a straight fit, rather than the forks. Much easier to replace a bracket.
Offline TjTalan
« Reply #31 on: April 27, 2020, 09:28:38 PM »
Good to know, thanks scottly!
My dream bike.
« Reply #32 on: April 27, 2020, 09:59:17 PM »
Did you fit a 3mm spacer between the hub and the right side brake rotor?
Offline jamracing
« Reply #33 on: May 18, 2020, 08:50:58 PM »
Read through this.
Damn, I'm glad I caught this... Bike was on the lift and getting prepped for partial lug-iotimy! I'll take it for a spin tomorrow and dbl check brake operation. I'll sharpie the rotor and see where the pad rubs.
Sent from my iPhone using Tapatalk Pro
Offline Keith
« Reply #34 on: May 20, 2020, 07:02:06 AM »
Yamiya makes a longer bolt and spring just for this!
Offline jamracing
« Reply #35 on: May 20, 2020, 07:11:42 AM »
$68 for these two parts including shipping. I'll pass...
Offline tacc13
« Reply #36 on: June 09, 2020, 11:04:36 PM »
Definitely don't need to shave the lugs. I found an excellent write up on the Blacksquare bike that I used for my conversion. It mentions the different lug lengths and using an extra space/washer. For some reason the link is dead but I probably have a download somewhere I can .pdf if anyone wants it.
Did you have problems getting the front wheel on with the dual calipers?
« Reply #37 on: June 09, 2020, 11:28:07 PM »
Thats the only real problem, to remove wheel both calipers have to be unbolted, but not disconnected
Offline robvangulik
  • Honda Fourever
« Reply #38 on: June 10, 2020, 01:38:42 AM »
That is quite common, with most later bikes with dual discs from the factory at least one caliper has to be removed to get the front wheel out.
Offline 750K5
  • agentsmith5
« Reply #39 on: June 10, 2020, 02:21:42 AM »
Subscribed
« Reply #40 on: June 10, 2020, 02:59:58 AM »
My CB750 K6 with dual brakes:
2nd caliper with mount must off before wheel. Hanging beside, oil line still connected
Std left caliper can sit.
Stock 1.85" rim, 100/90 or 3.25-19 tire.
Offline tacc13
« Reply #41 on: June 10, 2020, 03:15:24 AM »
CB550 with dual 750 calipers.
« Reply #42 on: June 10, 2020, 08:15:23 AM »
 I'm thinking on my 76F I used the stock bolt and moved the nut to the inside of the bracket next to the spring. It was the best stopping bike I've been on but I only ride old bikes.
Offline robvangulik
  • Honda Fourever
« Reply #43 on: June 10, 2020, 08:50:34 AM »
On my dual brake cb400 I can get the wheel out by deflating the tyre a little, with both calipers still in place ;D
Offline tacc13
« Reply #44 on: June 19, 2020, 02:10:01 AM »
Here's a .pdf of the website I mentioned earlier. It's a shame its gone as there was some good info on it. I have it in a .doc format as well so can edit and repost if anything needs updating or clarifying.
Offline ladyrocket
  • 1976 Honda CB750F
« Reply #45 on: June 22, 2020, 06:49:59 AM »
Checked my dual disc mounting setup last night.  Standard left caliper mounts flush to the fork, no washers, stock fender on the inside of the bracket (not between the bracket and fork).  Right caliper mounts flush to the fork for the lower bolt and the fender mounts between the top bracket and the fork to act as a spacer.  Remove the rubber mounting points from the fender and press in locking washers into the fender hole (it fits perfectly, got the tip from Godffery!).  This spaces everything perfectly.
« Reply #46 on: June 22, 2020, 06:54:19 AM »
 Just a passing note, I'm a big fan of the double disc front but moved my 750A front wheel assembly with 2 rotors on it yesterday and was reminded how heavy it seems. Rotor drilling is once again in my future. Somewhere I have the drill patterns printed out.
« Reply #47 on: July 04, 2020, 09:33:37 AM »
Bump for newbies.
Offline JohnG
  • 1976 CB750F - original owner
« Reply #48 on: July 05, 2020, 09:54:45 AM »
do you know for certain that the components on both sides are exact mirror images of one another?  In other words are you comparing apples and apples?
I did this several years ago.  Best modification I ever did.  Enjoy it!
john
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
« Reply #49 on: July 05, 2020, 12:48:57 PM »
that's the thing...it seems like everybody comes up with a slightly different story.  I think this is because the right fork leg not being finish machined, that castings can vary enough that the instructions for this mod must remain flexible.
