Author Topic: Having the right tools  (Read 1211 times)
Offline Keith
« on: April 27, 2020, 09:51:54 AM »
I have been receiving all the components to add the additional disc to my 750 K2, some of them in not-so-good condition. Everything is apart, and the threads are full of corrosion (galvanic action, steel and aluminum) So all threads have been chased, the bracket pivot taken apart, starting to paint everything before the new piston and seal are installed. As a former auto mechanic/technician, I am fortunate to have plenty of tools. This is a full-metric tap and dye set which sure comes in handy.
Online bryanj
Re: Having the right tools
« Reply #1 on: April 27, 2020, 11:28:39 AM »
Especially when the Japanese use the "non preffered" sizes
« Reply #2 on: April 27, 2020, 05:04:19 PM »
Quality tap and die set is very handy to have when needed. A friend of mine was a pro diesel mechanic so I have access to his Snap-On goodies.
Offline Keith
« Reply #3 on: April 27, 2020, 05:34:33 PM »
Pays to have the right tools. Snap On is good but very expensive! My dad used to call Snap On ratchets “knuckle busters”!because of their bad habit of the ratchet pawl reversing itself after a bolt was broken loose. I think time-serts are a must have item.
Offline scunny
  • don't call me expert
« Reply #4 on: April 27, 2020, 09:19:51 PM »
I was taught that you don't use a ratchet for heavy doing up or loosening, that's what power bars are for.
Look at the job, decide what will happen if the tool breaks free suddenly. choose another way, or put on gloves and hope.
tried all sorts, knuckles show the results  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #5 on: April 28, 2020, 04:13:38 AM »
I have a little tag of part of the cartilage or connective tissue under the skin of my middle finger’s knuckle that I sheered a couple decades ago when I busted a knuckle. I can push it around under the skin as far as its leash will allow. It is a tiny bump creating a bulge in the skin creating a whiter circle on the skin outlining it.
Offline kerryb
  • Not a very
« Reply #6 on: April 28, 2020, 06:32:46 AM »
My metric tap & die set came from Harbor Freight because I was too cheap to buy a good one...my SAE set came from sears.  I notice sometimes that the metric set seems to cut too much off leaving a looser fit than I would like.  Sometimes the nuts feel "sloppy".  Is this a result of poor quality tools, or is it more like phillips head screwdriver in a JIS screw head?
Online bryanj
« Reply #7 on: April 28, 2020, 07:04:08 AM »
Cheap tools with wrong tolerances
Offline Kevin D
  • SE Michigan
« Reply #8 on: April 28, 2020, 07:22:44 AM »
Snap-On tools are nice but they are lost just as easy as Harbor Freight tools. I have both but the good tools are for frequent use and the cheap ones for one time use.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Pielz
« Reply #9 on: April 28, 2020, 09:29:49 AM »
Haha! Gross!
Sent from my LG-G710 using Tapatalk
Offline Bodi
« Reply #10 on: April 28, 2020, 10:18:53 AM »
At least it isn't a CB77 with oddball pre-ISO threads. Try finding screws, let alone taps and dies, for those.
Offline Keith
« Reply #11 on: April 28, 2020, 07:08:02 PM »
Offline Keith
« Reply #12 on: April 28, 2020, 07:12:46 PM »
When chasing threads , don’t just crank in a continuous motion. Stop, back off, then continue,repeat. This breaks the chip that’s created and gives a more accurate thread.
« Reply #13 on: April 28, 2020, 07:42:33 PM »
Ha ha! Very true. ;D
« Reply #14 on: April 28, 2020, 07:48:09 PM »
If you think a CB77 has oddball threads, you obviously have never owned a 1953 BSA. Even the heads of some of the bolts were neither SAE or metric. ::)
Offline scunny
« Reply #15 on: April 28, 2020, 10:23:45 PM »
Whitworth ?
I have noticed that some of the Chinese manufacturers must have bought all British Leylands tooling.
They used to be advertised on the package as "metric machine screws"
But now they proudly display the Whitworth Standard.  ;D
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
« Reply #16 on: April 28, 2020, 10:42:44 PM »
Wasn't there also another "standard" than Whitworth? Something totally bastard... I seem to recall a hyphenated name??
Online bryanj
« Reply #17 on: April 29, 2020, 12:20:40 AM »
Britisn-Standard-Cycle, all sizes have the same tpi
