Author Topic: So, you want to run pods?  (Read 66315 times)
Re: So, you want to run pods?
« Reply #125 on: November 15, 2024, 07:23:59 PM »
I rebuilt my stock airbox and am going that route but I am surprised no one has chimed in about the steel dragon bread box. From what I have read on here there has been good success using them. That bread box also has velocity stacks built in.
Are they still in business?
I had an email back from them a couple of months ago saying they would build me a bread box so I assume yes
Those were the only airboxes I ever saw work pretty on the 750 - besides the OEM versions. They help with the open-air-tumbling issue, being boxed in.
On roadrace bikes we always had lower fairings that made a nice big airbox behind the engines, with directed intake paths for the carbs from that zone. That created a larger version of the ones Honda made for production bikes, and worked thru 3-digit speeds.
« Reply #126 on: November 15, 2024, 10:50:37 PM »
pods are crap full stop,end of thread?
Offline Dime
« Reply #127 on: November 16, 2024, 01:43:11 AM »
I have read some reports that the top of the steel dragon bread box, and in some cases the sides, had to be restricted. Other than that I have read good reports.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #128 on: November 17, 2024, 10:43:07 AM »
Having put some serious effort into tuning my carbs, my K&N pods work fantastic on my 77F although it must be said that my carbs are not CV. Smooth, responsive, and great consistent power through the RPMS
'77 CB750 SS
Offline Dime
« Reply #129 on: November 17, 2024, 11:07:49 AM »
They have their place. Maybe not on the factory carbs, but they do well on a set of CRs that I had on my dohc 750. That being said, I went back to the cv's and stock air box on that bike for streetability. Comparing the CRs to the stock carbs on the sohc isn't really fair all the same.
  • Money pit enjoyer
« Reply #130 on: November 17, 2024, 06:36:44 PM »
Are the CR carbs really that much better?
'77 CB750 SS
« Reply #131 on: November 17, 2024, 07:29:02 PM »
don't get confused.  The dohc bikes use carbs that have a cv piston...very sensitive to turbulent air.  Also keihin does not offer a wide selection of jet needles and needle jets for carbs supplied oem.  That is why the cr carbs can be made to work.  The tuning parts are available to solve all the problems pods cause....or just use the goddamn airbox.  Plenty of nice still air for your engine to suck, much more than it can use.
« Reply #132 on: November 17, 2024, 08:07:00 PM »
Dave, you're beginning to sound a bit like Two-tired, except without the pages of BS "science" to back up the claims. ;)
Lisa has logged thousands and thousands of miles on Dash, her trusty 550, equipped with K&N pods. ;D ;D ;D This pic is from her coast-to-coast-to-coast trip in '17.
« Reply #133 on: November 17, 2024, 08:56:48 PM »
Pods worked fine on my CB750 K6 with stock K6 carbs 86A.  Airbox should have restricted 836cc + ported head + cam.
Long trips on holidays in pouring rain as well as really hot rides. City rides at slower speeds too. Stock carbs easy to jet. Needle height and main jet.
I guess CV carbs are trickier?
« Reply #134 on: November 18, 2024, 07:14:34 AM »
Now that's funny - comparing Dave to TT!!!!!!
Offline kerryb
  • Not a very
« Reply #135 on: February 18, 2025, 03:50:47 PM »
And now for something a little silly!  Cv carbs, stock jetting, stock area size air filter, open triangle, hidden filter.  82 cb650sc.  I just didn’t want to deal with jets & tuning, stock performance is just fine.
« Reply #136 on: February 18, 2025, 08:27:29 PM »
Kerry wow!  That is a very interesting design
Offline kerryb
  • Not a very
« Reply #137 on: February 18, 2025, 08:47:44 PM »
It only has a few road miles on it, but the performance seems unchanged from stock.
« Reply #138 on: February 18, 2025, 10:04:47 PM »
Nicely done.
The CV carbs are off of?
Tell us about the box/filter assembly.
Offline kerryb
  • Not a very
« Reply #139 on: February 19, 2025, 06:57:51 AM »
Nicely done.
Carbs are stock for ‘82cb650sc, I’m not certain whether they are VB44 “B” or “C”, I can’t go look right now.  The duct work was made by wrapping foam shapes in 6 ounce fiberglass cloth and MAS epoxy.  The filter is a cabin air filter from a Mercedes sedan.  What isn’t pictured is the plastic restrictor plate with an air inlet the same area as the stock filter box.  The whole point was to get the look without spending time & money rejetting carbs and maybe reducing performance.
« Reply #140 on: February 19, 2025, 07:04:47 AM »
« Reply #141 on: February 22, 2025, 12:49:50 AM »
Ahh yes dash and lisa,may I start with that is a fantastic if not epic journey of biblical proportions no joke,this is a solid reminder to everyone especially new and maybe younger members here that even old jap junk bikes can go around the world even if the designers didnt intend it to do or even last 10/15 years?with city or suburb bound bikes using the entire rpm range often from idle to max over and again in short succession as opposed to sitting on mostly high rpm or the same rpm on the high way the use of pod filters will effect your carb tune to the point of losing some torque and overall engine flexibility over the entire rpm range,every one has different results and skills and patience to play with pod tuning,I recommend to use the stock factory fitted airbox.
« Reply #142 on: February 23, 2025, 03:34:14 PM »
Yeah Dave, that's the thing, you never know what you are gonna get.  I have had cb750's with pods that just run pretty good, pods, no pods, stock air box, no air filter at all, breadbox that falls off and ya don't notice because it runs no different....and I have had cb750's with pods that no amount of jetting will make them barely rideable.  Science says that there is always an explanation for this, and I am sure there is, but I have spent 100's of hours trying to solve these problems, but the only rule I have found is that every bike is different.
« Reply #143 on: February 24, 2025, 12:35:05 AM »
My K6 ran well with stock carbs and small pods.
836cc, ported head, cam and  loud 4-1 needed good flow of air.
Maybe carb related? If CV carbs can not use pods?
Offline carnivorous chicken
« Reply #144 on: February 28, 2025, 08:55:14 AM »
I'm playing around withr eplaced my pods with a stock airbox set up at high altitude and Scottly suggested I add my two cents here since the bike was running much better with pods before I installed the airbox.
I'm in Mexico City, so about 7500 feet elevation. 1976 CB550F1. Not sure of the make of the pods, but I can add a photo. Jetting is 38/100 (38/98 is stock, so assuming a PO rejetted). No markings on the jets, so assuming they are aftermarket. I should add: the o-rings on the jets are old, and they don't hold the jets in place, so assuming there might be some gas getting by them as well. Idle mixture screws 1.5 turns out. D7EA plugs.
Bike runs well with this set up, with great response and no flat spots. At 1200rpm idle it chugs a little and I get it a quick blip before taking off.
Switching over to the stock airbox, the bike idles smoothly and more quietly, but bogged at around 4krpm. I will likely switch back to the pods for now, but look at replacing jets and moving the needles to lean out the mixture. I'll use the formula Hondaman recommended me: 1.2% per 1000 feet of elevation -- so at 7500 feet + 9%. Stock main is supposed to be 98, so around 88.
« Reply #145 on: February 28, 2025, 07:10:13 PM »
The bike ran well with pods and 100 mains at your altitude. ;) If you think it's too rich, put in the stock 98s, if you have them. There is no amount of jetting that will replace the lack of air pressure at higher altitudes, which means that for every 1000 feet of elevation, you will lose about 3.5% horsepower. Thankfully, carburetors can compensate somewhat for these changes in barometric pressure, as they meter fuel based on the mass of the air flowing through the venturi: less dense air has less mass equals less fuel. If I had to change jetting every 1000 feet, I couldn't go 50 miles in any direction without two jet changes. ::)
« Reply #146 on: March 01, 2025, 06:47:11 AM »
Knowing I can just go back to what it was takes all the stress out of it (although I'd be getting new o-rings for those jets for sure...). Part of it is the challenge to get it back to stock with jetting and needle changes to see what it does. I'm usually a "if it ain't broke don't fix it" guy and was thinking that as soon as it showed signs of bogging, but I'll play around a little and see where it gets me. For my 350F here in CDMX, I just got some smaller jets and it seemed to be enough.
« Reply #147 on: March 04, 2025, 06:11:40 PM »
Please post a pic of the pods. ;D
« Reply #148 on: March 06, 2025, 09:15:07 AM »
Here they are, in their oily glory. Anyone able to ID? They don't look like the cheap emgos I've seen but they also don't look like they filter that much (similar to emgos).
I've got a thread going about not being able to find smaller Keihin jets:
http://forums.sohc4.net/index.php/topic,204808.msg2311555.html#msg2311555
But figured I'll summarize here. Stock main jets are 98s, and the next smaller that Keihin offers are 80s. I've ordered 98s to replace the aftermarket (and leaky) 100s that are in there now, along with 35 slows. I took out the air filter and the bike livened up but was definitely running lean, so I've bought some uni foam that will be here tomorrow (and oil, although that will take a little longer) to see what happens with 98s and less restrictive air filtering (I pick up the jets when I go to Ohio next week). another member chimed in who is at 4000+feet elevation to say he runs 90s that he got made to order from a place in AZ, so that might be another option after seeing how the 98s and less restriction goes.
« Reply #149 on: March 06, 2025, 10:11:23 AM »
 They aren't K&N's as K&N is embossed on the end cap. K&N's also have short velocity stacks built into the rubber mounting sleeve. I stated in another thread I've never mounted anything but K&N's on my side draft engines. Per asked earlier about CV carbs and k&N filters....my experience is they work well. Rubber diaphragm CV carbs are good carbs with the Mikuni's being the best IMO.
