Traditionally rather than focus on the squish on 750 heads, I got more benefit from the valves being so close to the edge of the bore I got good results by grinding a scallop on the edge of the bore next to the inlet and exhaust valves, down to about 1mm above top ring. This improved the flow right through the lift.
Two things that wasted my time on the 750 was looking for squish gains and and crankcase vacuum systems, very theoretical and minuscule.
Re the 15 :1 comp........ooooo that's out there man BUT I learnt to never say something is impossible , the modern Nascars all run 15:1 , it can only work on constant full throttle , no off on, Fuel would be a challenge , anything Ive done in the old days over 13:1 or 14:1 I had to use Methanol to get away with it, BUT I never had any involvement with constant full throttle with so who knows ?
Johno
