Author Topic: Euro handlebars not right measurements?  (Read 3075 times)
Offline Roby466
« on: May 02, 2020, 05:05:24 AM »
This is the 4th set of bars I put on my bike. When I got it the bike had drag bars which were not very good at all, I then got a set of cafe bars which I modified to fit (widened them). They looked great but were very uncomfortable!!  Then K got the M bars from the guy in the UK (can’t remember the name). These were great!  I loved them but the bike being my wife’s (inherited in parts from her dad before I rebuilt it) she wants to ride it now that she has gained experience on my old XT600 but the low bars made the bike feel heavier than it should.
So...  i ordered a set of euro original aftermarket bars from David Sylver spares. The bar came in with the holes for the controls pre-cut. Now the problem is there is a gap between the left grip and controls. Distance from center is equal left and right...  is this normal?
Thanks for the help once again!!
David
Offline rotortiller
Re: Euro handlebars not right measurements?
« Reply #1 on: May 02, 2020, 05:13:10 AM »
Looks the #$%*s, I'd get new bars un-drilled for wires and make the holes myself. Might try to make a new hole in the left bar more outboard so it becomes symmetrical provided there is enough room.
Offline Roby466
« Reply #2 on: May 02, 2020, 05:29:48 AM »
I know!  It looks bad!  I was wondering in Euro bikes had a different signal controls box...  weird!  I’ll write to David Sylver spares first. They normally have a great reputation they might send another bar.
Offline chiefum
« Reply #3 on: May 02, 2020, 06:31:52 AM »
These are the euro bars 53100-300-610P on my bike, I have the same issue. Let me know what DSS has to say, I have not contacted them yet.
Sent from my SM-N950U using Tapatalk
Offline Roby466
« Reply #4 on: May 02, 2020, 06:36:25 AM »
Ah!  Interesting!!  Weird they do that!  I’ll post back here when they get back to me.
Offline Roby466
« Reply #5 on: May 02, 2020, 06:38:19 AM »
By the way chiefum, I prefer those grips to the ones I have. Are they the original ones?  I better look again for them. Mine are a nit skinny and they make the throttle hard to hold after a while.
Offline chiefum
« Reply #6 on: May 02, 2020, 06:47:30 AM »
I believe these are called Gran Turismo style grips. When I purchased my bike, it came with this style. The old one's were quite a bit softer than the new one's.  I'll give them some time to see if they soften up.
https://www.ebay.com/itm/Beston-Gran-Turismo-Style-Grips-7-8-Handlebar-Chopper-Bobber-Triumph-Bonneville/191710474090
Offline chiefum
« Reply #7 on: May 02, 2020, 06:48:27 AM »
Thank you!
« Reply #8 on: May 02, 2020, 08:29:10 AM »
There is a circular lights on off switch that is for some markets and would fit in there.
The UK right hand switch is an odd one and ir was easy to go straight to lights off when you didnt want to and the circular switch sorted it
Offline scunny
  • don't call me expert
« Reply #9 on: May 02, 2020, 02:06:16 PM »
I would just cut the ends off of the bar.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: May 02, 2020, 02:39:00 PM »
And it's Scunny for the win!  ;D ;D
« Reply #11 on: May 02, 2020, 05:37:21 PM »
 I did a 71 a couple years ago and bought the K1 euro bars by accident. I loved them but they also had that gap. It ended up in England.
Offline Doobie
« Reply #12 on: May 03, 2020, 07:21:50 AM »
I had the same DSS handlebar on my CB750K6 and it's now on my CB750F3 and there's no gap in either case. It must be the DSS bar is only for later years because the switches and the holes line up differently (grips are different too).
Top is K, bottom is F
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #13 on: May 03, 2020, 10:14:01 AM »
My K2 has also that gap. I have not yet done anything about it.
Handle bar from a German eBay seller. K2 switches from 4into1.
I'll cut the handle bar 3-5mm. If gap is 2 mm no problem.
« Last Edit: May 03, 2020, 10:16:36 AM by PeWe »
Offline rotortiller
« Reply #14 on: May 03, 2020, 05:14:15 PM »
That would make the bars uneven if you only cut one end. If you cut both ends then I reason you created a problem at the other side as that hole will no longer line up when the grip and switch are moved inboard.
« Last Edit: May 03, 2020, 05:16:47 PM by rotortiller »
« Reply #15 on: May 03, 2020, 05:54:10 PM »
Very interesting so I had to go check my K2 and K4 as at least one of them has the DSS K1 bars ( I thought both but see below)
K4
K2
« Last Edit: May 03, 2020, 05:56:17 PM by andy750 »
« Reply #16 on: May 03, 2020, 08:56:55 PM »
K4
K2
Your K2 has later switches, right?
« Reply #17 on: May 04, 2020, 02:42:18 AM »
[/quote]
Ah good point. I believe you are correct.
« Reply #18 on: May 04, 2020, 06:01:37 AM »
My photo has real fake K2 switches that look exact as K2. The peg location too since other old switches have same "problem".
It seems that this model of handlebar fits K3 and later better.
I did not know that the location of  peg in switch differ.
I'll use my new tiger saw and cut bar a little when I have time and up for it.
I need to check throttle side too if bar can be cut.
If only left side, bar will be moved a little sideways to compensate. I'll not do the entire gap. Half or more will improve.
Offline Roby466
« Reply #19 on: May 05, 2020, 09:27:18 AM »
Hi,
Pewe, what is that extra button under your horn button?
And on the later switch, what is the hi lo for on the left switch?
Cutting the left handlebar will leave them uneven, cutting the right side will not fix it as the throttle also has a locating pin.
DSS told me they believe the original US market switches had no locating pin.  I am pretty certain the bike has original switches, father-in-law parked it in 1977 and it hadn't been touched until I restored it so I'm pretty certain I have the original switch, it says HM-100B-1 under the signal lever.
« Reply #20 on: May 05, 2020, 10:42:26 AM »
It is blinker buzzer off button. It switch off the buzzer when pressed. Typical K2.  Right switch also typical K2 with its specific shaped kill switch.
The gap is 5mm on my bike. No problem to cut 3mm on both sides. I'll see if I need to cut the throttle pipe too.
Offline Roby466
« Reply #21 on: May 05, 2020, 10:59:56 AM »
Thanks PeWe,
interesting functionality the blinker buzzer.
My gap is much more than 6mm, most likely almost 20mm so it will take a lot of cutting on that side.  Maybe if I remove the locating pins in the switches I will have more play before the wires get pinched but I am not sure if it will hold tight enough without the pins.  Oh well, I'll see I suppose since there doesn't seem to be an easy solution to keep it even.
Cheers
David
« Reply #22 on: May 06, 2020, 09:56:24 AM »
My K2 has the blinker buzzer attached and connected. Good reminder to not forget it on and get cars in front of you from a connecting road.
I was waiting at a red light with blinkers on and the buzzer alarm that sounds when blinker is not lit.
People in car in front of me started to look what the alarm was about. They had a car without roof. Half tent, half car!!
Must have been a cheaper version :D
I can sometimes press button and avoid the alarm when blinkers is used.
It was difficult to find CB750 buzzer. Most people must have done what I did with my K6 soon after purchase, removed and forgot it.
I found a Goldwing buzzer with 3 leads. Had to find a Goldwing diagram to verify which lead I should not use.
CB750 buzzers have only 2 leads.
K3-K6 have no buzzer off button.
Offline Roby466
« Reply #23 on: May 06, 2020, 12:56:38 PM »
That buzzer option sounds like a good idea so I don’t look like that guy riding along with signal lights on...
Thanks!
It appears there is no other model reproduction bars that would not have that gap so I’ll have to see about modifying them for better fit.
Thanks for the help and discussion!
David
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=c1gibai9f60n9n9pqqbq93n396&/topic,60973.0.html
« Reply #24 on: May 06, 2020, 02:51:00 PM »
make a nice alu spacer..
i hate all this v-w.... vords
« Reply #25 on: May 06, 2020, 02:54:50 PM »
You really are considering cutting both sides of the bar for a problem that exists in the left side only. I bet you cannot see that small difference if only left is cut and you will not feel it either.
Offline Doobie
« Reply #26 on: May 07, 2020, 04:24:44 AM »
The gap doesn't bother me visually and I'm usually OCD about little things like that. My first impression was that it's off in the same way many vintage things tend to be a bit off -- quirky but in a good way.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline Erny
« Reply #27 on: May 08, 2020, 03:44:26 PM »
I bought the same handlebars from CMSNL
did not installed them yet, but I target them to CB750 K7 (cables routed outside of bars)
For couriousity, I can check if I have the same as you - what is distance of hole from left bar end?
I purchased mine in March, 2019
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
« Reply #28 on: May 08, 2020, 11:23:20 PM »
It make the extra touch with cables hidden inside the bar.
Offline Roby466
« Reply #29 on: May 12, 2020, 06:12:28 AM »
Erny, thanks for checking.
The distance between the end of the bar to the center of the smaller locating pin hole is 6 3/8 in (or 16.2cm).
Note that I had to approximate the end as my grips are installed.
Thanks!
David
« Reply #30 on: May 12, 2020, 06:42:25 PM »
 I love the wires in the bars. It's a challenge and a pain, and so cool when it's done.
Offline Doobie
« Reply #31 on: May 13, 2020, 02:19:10 AM »
I swapped handlebars on my CB750F a couple of weeks ago and it was a real PITA and a relief when the ordeal was over. I've done this three times on different bikes and each time I swear it will be the last.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline Roby466
« Reply #32 on: May 13, 2020, 02:34:10 AM »
Many times for me...  still a pain and then there are always a couple of wires that you’re not too sure where they go in the headlight housing because their colour has faded differently than their male or female counterpart...  so much fun :)
« Reply #33 on: May 13, 2020, 06:52:01 AM »
My wires went in smoothly.
I read about it here when I searched about it.
Taped the harness to avoid loose ends when entering from each side and out in the middle.
