Author Topic: Will K7/8 750 flanges will fit on cb650 headers ?  (Read 932 times)
Offline Can550
« on: May 02, 2020, 06:07:20 PM »
Helping a friend to complete his Cb650 which is in need of 4 header flanges, cb550 are small. Will cb750k7/8 flanges fit?
Thanks
Offline Nicklopic
  • New York
Re: Will K7/8 750 flanges will fit on cb650 headers ?
« Reply #1 on: May 02, 2020, 08:33:39 PM »
I have a set. The flanges (and the collars probably) from my 650 if your buddy is interested
80' CB650
Build Thread
Offline Can550
« Reply #2 on: May 02, 2020, 09:00:34 PM »
Thanks I’ll pass him info
It is just so that we can get k7/8 flanges for free, would like to know if that will work.
Appreciated your reply and will contact you if he wants. How much would you want though ? Location ?
Thanks
Offline onepieceatatime
« Reply #3 on: May 03, 2020, 03:27:11 AM »
I have a K7 and a cb650. I think I have some flanges for each that are not on a bike at the moment. I'll try to remember to compare them when I get home from work tonight.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Can550
« Reply #4 on: May 03, 2020, 03:55:14 AM »
Much appreciated
Offline Nicklopic
  • New York
« Reply #5 on: May 03, 2020, 08:47:44 AM »
CB650 exhaust flange dimensions:
Bolt spread: ~58mm center to center
Flange thickness at mounting holes: 25mm
Inside diameter: 43mm
Inside diameter of the step for the collars: 49mm
Stem depth from inside flange surface: ~2.5mm
Overall height from inside base to tips of fins: 31mm
80' CB650
Build Thread
Offline Nicklopic
  • New York
« Reply #6 on: May 03, 2020, 08:50:02 AM »
If 750s don't work and you'd like mine, I'm located on Long island/New York. I have no idea the going rate would be so just shoot me some offer. If you're in the states I can probably fit them in a flat rate box without issue
80' CB650
Build Thread
Offline Can550
« Reply #7 on: May 03, 2020, 02:03:26 PM »
Much appreciated Nick
I’ll pass the information to him
Once again many thanks for taking time to measure.
« Reply #8 on: May 03, 2020, 04:14:45 PM »
The K7 ones will not fit the 650. The flange holes are to far apart to fit the studs on the 650 head. They are also heavier, being steel instead of aluminum.
Sent from my Pixel 4 XL using Tapatalk
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Can550
« Reply #9 on: May 04, 2020, 06:24:33 PM »
Many thanks
