Author Topic: CB750K1 "Keep on the road"  (Read 5262 times)
Offline chiefum
« on: May 06, 2020, 01:53:34 PM »
I recently picked up this CB750K1, while not really a project, I am learning maintenance and upkeep on this old bike. I'm fairly new to vintage bikes, but have some auto mechanic knowledge.  I will probably be posting a lot of questions,  as I don't personally know anyone with experience on vintage motorcycles.
Sent from my SM-N950U using Tapatalk
Offline chiefum
Re: CB750K1 "Keep on the road"
« Reply #1 on: May 06, 2020, 01:59:09 PM »
I noticed the tach was jumpy at certain rpms.  First I replaced the cable which looked a little worn out. The problem persisted,  so I decided to try and renew the gauges. I wanted to keep the patina of the gauges,  so I cleaned, replaced seals, refilled the damper pots, but kept the original faces. I also put in some led lamps for the backlights. They also liked to fog up prior to my cleaning them.
Offline chiefum
« Reply #2 on: May 06, 2020, 02:05:08 PM »
The original tank had a red liner that was starting to fail. I searched for a replacement,  but I couldn't find any that were better than mine. Since I've never attempted to remove a liner, I had it sent out and they did their best to remove the old and replaced with a Caswell liner. I also added two inline fuel filters for peace of mind.
Offline chiefum
« Reply #3 on: May 06, 2020, 02:11:59 PM »
My next order of business was replacing the old tires from 2009. I went with Heidenau K36 and K44. I also decided to replace the wheel bearing, rubber dampers, sprockets, and chain.
Offline chiefum
« Reply #4 on: May 06, 2020, 02:14:48 PM »
It appears someone torqued the front axle when the speedometer drive wasn't lined up. So I've ordered a replacement.
« Last Edit: May 06, 2020, 07:56:51 PM by chiefum »
Offline chiefum
« Reply #5 on: May 06, 2020, 02:18:45 PM »
Dropped the carb bowls to take look. Pilots look like original 40's. Mains are 100 with an "AB" on them. Should the mains be larger?
Offline chiefum
« Reply #6 on: May 06, 2020, 02:32:39 PM »
I swapped out the original handlebar to the euro one from dss. The low beam burned out, so I found a replacement headlight. I also adjusted the valves, cam chain tensioner,  and did a cold compression test. I also added the Hondaman key saver and headlight switch saver relays.
« Reply #7 on: May 06, 2020, 06:12:18 PM »
One nice ride. I’ve kept my K1 in much the same manner and it is the bike I ride the most. Took it out for the first run this year today. Are those K7/8 pipes or something some one built? They look great!
« Reply #8 on: May 06, 2020, 06:13:57 PM »
Beautiful work and love the photos/attention to detail. Very very nice! Are you in Wisconsin? If so you may be near Johnnie a WI SOHC expert with more than a few CB750s.
Keep posting its very inspiring!
cheers
Andy
Offline chiefum
« Reply #9 on: May 06, 2020, 06:58:04 PM »
Your bike looks very nice. They are the factory headers with Hooker mufflers.
I didn't know what they were until I seen some posted for sale on Facebook. I think I have a pic.
« Last Edit: May 06, 2020, 07:54:35 PM by chiefum »
Offline chiefum
« Reply #10 on: May 06, 2020, 07:48:46 PM »
cheers
Andy
Thank you! Yes, I'm about 20 minutes from Johnie, I've been to his shop and drooled over some of his bikes.
cheers
« Last Edit: May 06, 2020, 07:59:39 PM by chiefum »
« Reply #11 on: May 06, 2020, 11:06:39 PM »
Beautiful exhaust...
Jets-R-Us has genuine Keihin jets...
Offline chiefum
« Reply #12 on: May 07, 2020, 03:37:44 AM »
Thank you, the pics of the exhaust was a NOS set that I saw on for sale on Facebook,  unfortunately mine are not as beautiful.  I will most likely order some jets from there, I'm not quite sure on which sizes to order yet.
« Last Edit: May 07, 2020, 04:23:52 AM by chiefum »
Offline chiefum
« Reply #13 on: May 16, 2020, 07:38:21 PM »
I decided to rebuild the master cylinder,  caliper, deglaze the front rotor, and replace the front brake pads.
Offline chiefum
« Reply #14 on: May 16, 2020, 07:41:33 PM »
The front brake must still have some air in the line, it's still a little spongy.  I ran out of time and I'll have to try bleeding it again another day.
Offline Johnie
« Reply #15 on: May 17, 2020, 06:21:50 AM »
Coming along good there. That is some nasty stuff in the caliper...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline chiefum
« Reply #16 on: May 17, 2020, 06:46:52 AM »
Thanks Johnie! It was pretty nasty, I'm hoping this refresh will help with the braking.
« Reply #17 on: May 19, 2020, 07:13:20 PM »
What front brake pads did you end up using and was there any issue fitting them?
Thanks
Andy
Offline chiefum
« Reply #18 on: May 19, 2020, 07:19:41 PM »
Thanks
Andy
I used these, I just had to remove some of the paint with sandpaper until it fit in.
Offline chiefum
« Reply #19 on: July 25, 2020, 09:59:59 PM »
Finally got the front brake all set. Reverse bled the line, it was super easy. Replaced this also. Glad to be back on the road.
« Last Edit: July 25, 2020, 10:03:07 PM by chiefum »
« Reply #20 on: July 26, 2020, 02:58:35 PM »
Here’s a really anal tip, that makes a difference. When you finish bleeding, roll up a tiny piece of shop towel and jam it downthe bleed nipple. Wick allthe leftovers out, then spraying a bit of WD40. Install a rubber cap and it will be clean for next time!
« Last Edit: July 26, 2020, 10:00:42 PM by BenelliSEI »
Offline chiefum
« Reply #21 on: July 26, 2020, 03:00:53 PM »
Here’s a really anal tip, that makes a difference. When you finish bleeding, roll up a tink piece of shop towel and jam it downthe bleed nipple. Wick allthe leftovers out, then spraying a bit of WD40. Install a rubber cap and it will be clean for next time!
I did the shop towel part, but I did not do the wd40 part. I'll do that, I also got the new replacement rubber with the bleeder.  Thanks for the tip!
« Reply #22 on: July 26, 2020, 03:03:06 PM »
Great! Keep up the good work. Like me, you appear to enjoy the tasks as much as the ride. Great combo!
Offline chiefum
« Reply #23 on: July 26, 2020, 04:03:56 PM »
I really do enjoy it, it's a great learning experience and very satisfying to do the repairs and upkeep myself.  Thanks BenelliSEI!
Offline gpzkat
« Reply #24 on: July 26, 2020, 05:52:37 PM »
Very good looking bike and nice work. I am aspiring to get my '73 project into similar shape, will try.
