Author Topic: This weekend I'm picking up a 1980 CB125 for 100 bucks. Pretty excited  (Read 10516 times)
Offline grcamna2
The airbox looks just like mine. I'm not sure how similar they were but it almost looks like that tank doesn't go with that model of CB125 but it's hard to tell. I can only see the "198" of the date stamp
OK,I see that,someone stuck that newer model CB125S tank on the 1980 model.
Offline Pielz
I ordered that new boot. Here's the link if it still works
https://www.ebay.com/itm/133450269966
Offline grcamna2
I checked it out,fellow wants a premium,although I shouldn't talk..  ::)   When it's NLA then can ask more.
Offline Pielz
Yeah I would have been happier with 20 bucks but given that it's the only one I could find on ebay that's not damaged, I don't have a lot of choices!
Offline grcamna2
OEM rubber parts have lasted a Long time.That rubber intake duct could last another 30 years.Have you ever done the Wintergreen oil treatment for rubber,it really freshens the rubber up.
Offline Pielz
I've been meaning to do that but wintergreen oil is so expensive thanks to the essential oil craze
Offline grcamna2
Yes,I've been looking.I bought some a while back,had to do a lot of searching and found 4oz. of 100 pure natural wintergreen oil,less than $10 !
« Last Edit: June 27, 2020, 03:12:09 PM by grcamna2 »
Offline Pielz
Wow everything I was seeing was for like 40 bucks! If you find a link, send it my way!
Offline onepieceatatime
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
http://trjkarting.com/wintergreen-tire-prep-quart/
Excellent looking product 'opaat',have you purchased and used this to soften rock-hard rubber carb. intake manifolds ?
I have not bought or used anything to soften up rubber, but I have read about go cart folks likeing it for their tires. Softer rubber, better grip, and since that's what it is marketed for, you avoid the essential oil prices. I think I have seen a couple other brands of it too, but that is the first one that came up in a google search.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
That a 12oz can ?
That a 12oz can ?
It says quart, so 32 oz, I guess.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Pielz
Wow that's a great deal! Ill see what the status is on that rubber boot and I might order this. Thanks, Roy!
Offline grcamna2
Perfect,should last years for many different jobs,thanks for the link to that.
« Last Edit: June 27, 2020, 06:33:57 PM by grcamna2 »
Offline Pielz
Little update to this thread. Got the bike to start and run! Fuel line was clogged, swapped that. Hooked up the Honda OEM used coil I got and put on the intake boot and it fired up after only about 45 kicks realized the exhaust was leaking at the head. Further testing proved the exhaust is plugged up completely. Of course it is! Heated the pipe up a little and poked at it with a drain snake. I left some degreaser in it overnight.
Tomorrow I'll see if I can take it to a truck shop and see if they can blow out whatever the blockage is. Might try muriatic too. Who knows what'll work. The header doesn't disconnect from the muffler so my options are limited.
Offline grcamna2
I hope the shop with a huge air compressor and 180 psi. line pressure(through the blow gun)will help you.I used to go to this powder coating shop just down the road in a little town named Export,PA.They PC'd many parts for me;I once asked the worker if he would sand blast into the inlet of one of my mufflers,it did get lots of sand in it but cleared out a lot of rust and made it run better.I'm glad nobody followed me too close  ;D for the first few miles when i was blowing it out,they might have gotten sand blasted !
Offline Pielz
Sounds a little like a James Bond style getaway gadget! Lol. I hope they're willing to do that for me. If not I have a friend with a 33 gallon compressor. Maybe 120 psi would be enough?
Offline grcamna2
A good blast of 120 psi sure wont hurt it.
Offline Pielz
Little update: got new brakes, painted almost everything I could, removed rust from as many pieces as I could get to, and I'm working on the wiring now. New sprockets are on and wheel bearings are in the mail. Exhaust was cleaned out and clear coated with high temp clear.
Its looking pretty good! Won't be long now and you'll have a fun little around town bike!
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
Re: This weekend I'm picking up a 1980 CB125 for 100 bucks. Pretty excited
« Reply #71 on: August 07, 2020, 10:48:18 PM »
How's it running Pielz ?
Offline Pielz
« Reply #72 on: August 07, 2020, 11:20:37 PM »
I kinda burnt out and haven't been doing much to it. I was hoping tomorrow or Sunday I can do what I needed to still. Timing and wiring and stuff. I got a long m3 bolt to see if that's the right size for the cam chain adjuster. It's a little low on power so I'm thinking I gotta do more than just static timing. It's got a little rattle in the upper rpms that I'm hoping is the coil or something rattling against the tank and not the cam chain but I guess we'll find out when I mess with the tension.
Offline Pielz
« Reply #73 on: August 10, 2020, 05:01:26 PM »
A little update. I got the running issues figured out. Slow jet was clogged and bowl was full of dirt even after my first Clean. Must have had some crud in the tank leftover. Clean carb now and new fuel filter has it running perfectly. I really opened her up around the cemetery and rich people's development up the road. Engine compression is phenomenal. Engine braking is amazing.
The fuel door on the top of the tank rattles a lot at high rpms. I have the rubber trim for around the edge of it but it still rattles like crazy. I guess I gotta figure out something to do for that. Other than that I ordered a headlight and universal ignition switch and steering lock. Should work well. Speedo works great as well. Brakes work pretty nicely. Starts first kick. Good little bike
Btw that screw for the cam chain adjuster trick worked great. It was a 40mm M3 1.5 pitch screw.
Offline grcamna2
« Reply #74 on: August 10, 2020, 06:02:52 PM »
I'm glad to hear that you have the bike on the road,running it through the gears  8).That fuel tank door over the cap is a little finicky.. there's a type of metal spring/tab in there that you can slowly bend to tighten-up how much tension is applied to the door;I hope it hasn't snapped off in a previous life.How is the break-in coming along on your engine,change the oil and running it hard ?
