Recently had the carbs redone and a top end rebuild. Been driving around for a couple of months and in the last two weeks the bike had been dying after 30 mins or so of solid riding, good in first and then bucking in 2nd. The hive mind thought it could be a fuel cap vent issue so I cleaned it out with a vinegar soak and then drilled it, and replaced the gasket.
Was just riding around and same thing happened. I limped the bike home and checked the cylinders with some spit and the 3rd was not boiling hot. I also drained the Bowles and they all were full except the 3rd, which had some drips (as opposed to the solid trickle).
The jets are all new so I don’t think they are clogged, so does anyone else have a thought? Could it be a stuck float?
