Author Topic: Is copaslip ok as anti-seize for stainless fasteners?  (Read 883 times)
Offline JWB
« on: August 04, 2020, 12:27:12 PM »
To stop the galling\galvanic corrosion between stainless fasteners and aluminum or steel I have read here some people recommend a zinc based anti-seize.  I have Copaslip in my home shop and wondering if it works just as well even though it isn't zinc based.  I don't want to cheap out on something so simple and cause a nasty problem in the future.
Offline jukku
  • Happy with my Hondamatic
Re: Is copaslip ok as anti-seize for stainless fasteners?
« Reply #1 on: August 04, 2020, 01:08:18 PM »
Zink is better because it is a less precious metal and sacrifice itself.
Offline robvangulik
  • Honda Fourever
« Reply #2 on: August 04, 2020, 02:07:30 PM »
I switched to Ceramic paste, because that is totally inert in that respect, unlike copper which still reacts between different metals.
Offline maxheadflow
« Reply #3 on: August 04, 2020, 06:27:28 PM »
I simply use blue Loctite.. I'm sure any antisleeze will work.
Offline JWB
« Reply #4 on: August 05, 2020, 10:01:04 AM »
I contacted Alloy Boltz where I purchased the stainless bolt kits from and they said to use Z-24 threadlock.  I think that fits in pretty well with the information you all provided.
« Reply #5 on: August 05, 2020, 01:14:19 PM »
To me threadlock and antisieze are at opposite ends of the spectrum
Offline scunny
  • don't call me expert
« Reply #6 on: August 05, 2020, 02:15:26 PM »
I was thinking the same Bryan. Why would you want to make it harder to remove the screw or bolt from soft aluminum ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline maxheadflow
« Reply #7 on: August 05, 2020, 04:35:06 PM »
First off, cast aluminum isn't all that soft, it's more brittle than say 3003 or 5052.   Second, you want to think of blue loctite as a quick setting removable cement. The good thing about it is that it seals the threads and actually acts as a lubricant when broken free.   I've been using it for years on SS screws without issue.   SS needs something to act as a lubricant for sure.  I've locked up SS nuts on SS bolts when getting lazy about applying some sort of thread stuff.
Offline JWB
« Reply #8 on: August 05, 2020, 04:45:03 PM »
Thanks Maxheadflow, that is what the vendor that I used said.  I also checked with another fastener company about SS and aluminum and they endorsed the same product.  Good to know someone has been using this product for years without issue.
Offline scunny
« Reply #9 on: August 05, 2020, 04:52:32 PM »
Oh well, all is good then, I learnt something new today, which is always welcome.
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
