Author Topic: Tool for rear wheel bearings CB500/550  (Read 649 times)
Offline JBMorse
    • Travel Blog
« on: May 16, 2020, 05:43:33 AM »
I’m gearing up to replace the rear wheel bearings on my CB500k while my swingarm is off at Hondaman’s. I did this job 12 years ago, and am reviewing the procedure and collecting parts. I remember tapping the old bearings out was a challenge.
Have any if you used a removal tool like this?
https://www.denniskirk.com/motion-pro/bearing-remover-set-08-0269.p282563.prd/282563.sku
I like the concept and it looks like it would work, but I remember these bearings required some hard blows to come out and I wonder if this type of remover would hold up. One reason I like the looks of this tool is it seems I wouldn’t have to mess with that pronged inner spacer.
Any advice, encouragement or ridicule is welcome!
Thanks,
Jeremy
1971 CB500K
Offline onepieceatatime
Re: Tool for rear wheel bearings CB500/550
« Reply #1 on: May 16, 2020, 05:55:10 AM »
I bought one like that, but have not used it yet.
That is the type recommended in my Goldwing service manuals. What I have used in the past is a long bolt welded to the bearing race and a big hammer. I tried a slide hammer bearing puller, the bearings would not budge, and the part that grips the bearing bent.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Ksgfx
« Reply #2 on: May 16, 2020, 09:09:00 AM »
I tried a bearing puller on my 500 as well and wouldn't budge. As a bonus I also messed up the little collar that goes inside the larger bearing so I had to replace that. Be careful if yours has a collar, they damage easily. I ended up using a large brass drift and a small sledge hammer. It took a lot of beating but they eventually came out. I did us a motion pro set, along with the old bearings, to put the new ones in.
72 CB500 K2
70 CL350 K2
72 CB450 K5
73 CB450 K6
75 CB750 F0
Offline tlbranth
« Reply #3 on: May 16, 2020, 10:58:17 AM »
I use a wedge-type concrete anchor to grip one of the bearings. Then I bash it out from the other side with a punch or piece of steel rod. The second one's easy with the spacer removed. Might cost you a buck fifty.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
