Author Topic: CB750 K5 tach cable routing?  (Read 413 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: May 21, 2020, 12:02:42 PM »
Does it go behind the brake splitter like this?
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: CB750 K5 tach cable routing?
« Reply #1 on: May 21, 2020, 12:30:32 PM »
goes straight down and thru a metal "loop" bolted to the inner lower tripple clamp, then arcs toward the engine,
and passes thru a skinny clip type of guide that is bolted to the horn, then goes into drive at the cover.
might help to look at a parts diagram.
