The wet weather has continued today, the poor cats have been hiding from the thunder and lightning which has flooded my patio workshop, only the Z1-B and workbench have survived relatively dry. Working from home has been particularly quiet this week with a public holiday on Wednesday, a lot of the public servants that I'm so lucky to work with took the whole week off. Oh well, I decided to make the most of my paid "Quiet Time" and prepare my shiny new gas tank. I brought the box inside and Leo decided that he owned it, but I kicked him off it when he started ripping up the bubble wrap that the tank was packed in.
Z1 Friday 28 Jan 2022 by
Terry Prendergast, on Flickr
I let him keep the box after I removed the beautiful tank.
Z1 Friday 28 Jan 2022 1 by
Installing the tank furniture was a real "heart in the mouth" situation, especially installing the spring loaded cap latch. I thought I took a pic of all of the masking tape and shop towel that I taped to the top of the tank to avoid scratching it when I had to tap the "Roll Pin" into the fuel cap's hinge mechanism, and then the gut churning method of using a centre punch to expand the end of the rivet on the spring loaded latch. Took way longer than it should have because I was sh1tting bricks, the last time I had a shiny new gas tank was when I smashed my shiny new CB750F over a gutter, thru a tree and into a "Give Way" (Yield) sign @ 90MPH when I was drunk, in 1978, and "Boomeranged" the original..... Anyway, I managed to get it all together without any damage, and mounted it on the bike temporarily.
I need to do a compression check (only because I haven't done one) re-do the ignition timing and change the advance curve because after reading the Dyna 2000 blurb, I'm using the wrong advance curve and not quite enough ignition advance, adjust the clutch (I seem to have way too much clutch cable, for same reason?) adjust the mixture screws, install the horn, and make a centre stand "Stay" to stop it acting as a chain tensioner. Only little things, but if the rain pisses off, I might actually get it done.
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
Z1 Friday 28 Jan 2022 3 by
