Author Topic: 1980 cb650 running rich.  (Read 796 times)
Offline Jetpilot1
« on: May 23, 2020, 09:35:12 PM »
1980 cb 650 custom, stock except for 4 into 1 exhaust.  Running rich.  95 main jets.  Float level checked to 12.5 mm, not leaking, holds 5+ psi all day.  Going to try clear line fuel bowl level check, but how high should the fuel go in the line?  Mixture screw set to 1.5 turns.  I noticed no o ring on idle needle - any chance this is causing richness?  Going to 90 main jets and fixing o ring issue.  Any ideas?  O yeah- stock intake box.
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: 1980 cb650 running rich.
« Reply #1 on: May 23, 2020, 09:56:57 PM »
Running rich at idle or on load?
Main Jets are only affected at mid throttle so changing that will likely make minimal if any change if you are experiencing a rich condition at idle.
This chart has always been helpful:
Offline Jetpilot1
« Reply #2 on: May 23, 2020, 10:03:52 PM »
Seems rich across the board....
« Reply #3 on: May 23, 2020, 10:28:20 PM »
There was a bulletin from Honda about 650 and drilling airbox but cant remember which model and dont have access to by bulletin book
Offline TurtleSnifferII
« Reply #4 on: May 24, 2020, 12:41:03 AM »
Is it this?
« Reply #5 on: May 24, 2020, 02:05:12 AM »
Thats one but my aged memory tells me there is another
