Author Topic: CB550 with a CB650 engine: research for future project  (Read 4450 times)
Offline onepieceatatime
Re: CB550 with a CB650 engine: research for future project
« Reply #25 on: May 22, 2020, 11:25:51 AM »
Yes, I appreciate those numbers 'opaat'(onepieceatatime)  :) Thanks Man.  ;) The 79' CB650 is a lot more like the CB550 and the parts are a closer fit.I want to set one up with round top carbs. When all these parts and pieces do get to me and sitting in front of me,I will begin my assembly.I will need to figure-out what rubber intake manifolds to use on this;I think/hope the airbox rubber boots will connect-up,depending whether I get a CB550-650 eng swap or a 1979 CB650 motorcycle.
I can measure the rubber boots and intake side of the carbs too if you would like. I'll be back at the garage tomorrow.
Sent from my Pixel 4 XL using Tapatalk
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Scott S
« Reply #26 on: May 22, 2020, 11:32:11 AM »
 About halfway down page 4, I start covering the 650 swap. Hurry now and you can see the pics, before Photobucket limits the monthly bandwidth!
http://forums.sohc4.net/index.php/topic,67907.75.html
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline grcamna2
« Reply #27 on: May 22, 2020, 03:18:14 PM »
Opaat,
Do you have CB650 rubber manifolds for the early head ?
75' CB400F/'bunch o' parts'
Offline grcamna2
« Reply #28 on: May 22, 2020, 03:20:24 PM »
Scott S,
I looked(decent pics about to expire,thanks :)) and learned what you and your Father did for the swap.
How did you work out the clearance for the bottom of that header ?
Offline grcamna2
« Reply #29 on: May 22, 2020, 03:23:30 PM »
The numbers look good  8) on the 79' CB650;why should I swap a 650 into a 550 when the 79' 650 is good.  :)
Did you ever own a 79' ? How does it handle compared to the 550 ?
I found in the 550 manual that it’s dry weight is 400lbs. So that’s 30lbs lighter than the 650. So it’s lighter but the difference could easily be made up with a fat rider.
The later cruiser type 650’s are not as easy to turn into a traditional cafe style bike (if that’s what one is doing) so the swap makes sense. If you have an earlier year 650 that runs and rides well then I don’t see a reason to find a 550 to swap the motor into. BUT if you have a 550 that you’re looking to upgrade and come across a 650 parts bike then it’s a no brainer. What I had was a well running 550 and found a 650 for a few hundred bucks. Did the dynoman 674cc big bore kit, megacycle 126-20 cam, MRieck’s stage 2+ porting and CR carbs over a year or two while I was having fun with the 550. Swapped it over a winter and had a 30+ hp increase. It feels good.
Dave,I remember your build  :) thread and was watching it come together while you built the Patina Hyena.I also liked when you chose to pump-up the engine and wanted to ask,now that you've had a couple years to enjoy the finished product: How do you like the bike and have you been able to keep-up with any other bikes that surprised you? are you glad you did the swap rather than just getting a CB650 ? Can you tell the difference in handling between an early CB650 and the CB550 ?  Thanks,Bill
I love the bike. It still makes me smile when I really give it the beans. As James May would say, it gives me the fizz. I don’t really ride with a lot of other people but I was on a ride with guys with new bikes (not crotch rockets) and I’m right there with them. They were definitely surprised. Getting a 650 wasn’t even a thought, I wanted to do a swap and that’s what I did because I like the aesthetics of my bike. I have never ridden a 650 so I can’t speak to the handling. I imagine the later years didn’t handle as well as the earlier years since they were pretty much a 550 that hit the gym vs a cruise type. Are you veering towards just getting a 650 or still contemplating a swap?
Dave,I hope to see how a fellow member here likes the handling of their 79' CB650.The bike has an inch longer wheelbase than the CB550,was wondering how the rake and trail are different than the 550.
« Reply #30 on: May 22, 2020, 03:44:54 PM »
Opaat,
I have '80 and '81 parts. The '80 engine, carbs, and mount rubbers are the same as the '79. I don't know if the air box and those rubbers are the same though.
I have both models from '80, a complete '81 custom with no title, and 2 incomplete standard model parts bikes, one '80 (engine was blown) and one '81, plus a spare '80 engine.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
« Reply #31 on: May 22, 2020, 03:47:28 PM »
The 80' have the same airbox as the 79'? Would you see if a pair of round-top CB750 carbs will fit into that if you have the parts ? Thanks  :)
« Last Edit: May 22, 2020, 03:49:42 PM by grcamna2 »
Offline Scott S
« Reply #32 on: May 23, 2020, 05:59:40 PM »
Scott S,
 Honestly, I don't remember. I think I just moved it around as we tightened it up and it cleared.
'71 CB500 K0
'81 Yamaha XS650
« Reply #33 on: May 23, 2020, 07:34:21 PM »
I looked up part numbers, '79 and '80 have different part numbers for the airbox and airbox rubbers.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
« Reply #34 on: May 23, 2020, 08:13:52 PM »
Oh,
Do you think the round-tops might fit the 1980' airbox rubber flanges ?
« Reply #35 on: May 24, 2020, 10:09:58 AM »
Oh,
They will fit, but the rubbers are loose, so I don't know how well they will seal even with smaller clamps.
CB650 carbs
Round top carbs
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline grcamna2
« Reply #36 on: May 24, 2020, 10:14:52 AM »
Thanks for that 'Opaat',I appreciate you measuring.I'll figure out a way to add custom flange parts if it comes to that.  ;)
« Reply #37 on: May 24, 2020, 10:35:45 AM »
No problem!!  8)
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
