I'm waiting for local shop to mount tires on new 18" Excels - 110/80 and 130/70 on 2.5 front and 3.5 rear respectfully. It's a bit overkill, but have Ohlin internals for the GXSR front end. Calculated trail and got a very nice 45mm triple tree set from Devin. It should work out to be within a few mm of stock, so can perhaps drop the tubes a wee bit or get longer rear shocks.
Rear is currently Ikon, but will be looking at some other options.
Just installed new 3.0 Ohm coils for the Dyna 2K I am putting in.
I'm going to ride it for a few weeks, then the head is going to Mr. Rieck for a Stage 3, or maybe even a 4. Finally decided on a 915 kit (JE) with new sleeves, and likely CR 31 carbs. APE will get the crank. Haven't decided on the cam yet. Only mountain roads here.
