Author Topic: How it Works, Honda Mechanical Disc Brake Caliper.  (Read 846 times)
« on: May 30, 2020, 12:35:36 PM »
 If you were wondering about these, they were used on some smaller models, like the 200 twin and others.
 I took one apart, got a few pics. Will try to explain it a bit.
Offline Alan F.
Re: How it Works, Honda Mechanical Disc Brake Caliper.
« Reply #1 on: May 30, 2020, 12:38:15 PM »
I'd been spending some time on  the Twins forum and read some about them but saw no good photos or read any theory of operation.
Subscribed.
« Reply #2 on: May 30, 2020, 12:48:13 PM »
In the first pic cable has been disconnected, would  below where it is in the pic inside that caliper half.
 There us about a 10 mm slot in the main part of the caliper, it's where the disc travels..the main hole is above and below this, the stationary  paid sits in the lower blind hole. The other hole is where the sliding pad is doing the work. Sliding back and forth in about a 19mm long section of the hole.
 The plastic part pushes against the second half of caliper, a lot of the mechanism  is inside that half.
 The actuator, is pulled by the cable, it is a lot like the clutch lifter on a 750, 3 balls and ramps.
 Between this and the plastic section three is a thrust bearing, to smooth out the action of things moving..
Offline grcamna2
« Reply #3 on: May 30, 2020, 12:53:50 PM »
Frank,How does the area underneath that white plastic disc look ? There is a threaded center 'screw' of sorts that self adjusts, which that white plastic disc fits into the end.
« Reply #4 on: May 30, 2020, 12:57:44 PM »
 I think that was good it's in a bag right now .
 I have added a pic I took off the net, to show the central bore that the sliding pad rides in.
« Last Edit: May 30, 2020, 01:00:47 PM by 754 »
Offline Alan F.
« Reply #5 on: May 30, 2020, 01:00:18 PM »
Sounds like a slick bit of engineering. I have heard that these weren't very powerful brakes though. I wonder how much improvement can be made with different rotor material and better pads? Duals?
« Reply #6 on: May 30, 2020, 01:03:00 PM »
I don't know if you can get pads, and I doubt there is much if any choice.
Offline grcamna2
« Reply #7 on: May 30, 2020, 01:07:47 PM »
I have done lot's of looking,there are limited supply of pads available:sometimes I see one side,then later the other pad.
« Reply #8 on: May 30, 2020, 01:12:35 PM »
Oh one other thing, I sort of liked..
 The stationary pad has a pin on the back similar to the others, but no cotter.
 There is a rubber grommet in there, the pin just pushes in, a bit snug. Pad has the small bump on the back to let  it swivel..
Offline grcamna2
« Reply #9 on: May 30, 2020, 02:01:15 PM »
That looks good
« Reply #10 on: May 30, 2020, 10:54:19 PM »
 I have a set of Lincoln mark V rear disc brakes going on a 9" ford rear end. The E brake is built in to the caliper and that's how they work. GM had some like that on the big front wheel drive cars too.
Offline grcamna2
« Reply #11 on: June 04, 2020, 12:16:18 AM »
Frank,
I appreciate you offering this caliper to me and a fair price.I tried sending a PM to you a couple times earlier.I sent the $ to you again a second time today,this time the full amount in US $:did you receive my full payment for this caliper plus shipping ?  Bill H.
« Reply #12 on: June 04, 2020, 02:36:01 AM »
 Yes Bill , it all came thru, Thanks...will send today.. Frank
Offline grcamna2
« Reply #13 on: June 04, 2020, 08:09:25 AM »
Ok,thank you.
