Author Topic: small honda help  (Read 1390 times)
Offline 74cb750
small honda help
« on: June 04, 2020, 08:25:26 AM »
hi aLL
anyone know of a good website/group for help w/ small honda's?
thanks,
michel
Laugh at least once a day.
Life  $ucks, then you die.
Re: small honda help
« Reply #1 on: June 04, 2020, 08:31:44 AM »
How many different small Honda's do you have ?
Offline Scott S
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline 74cb750
« Reply #3 on: June 04, 2020, 09:30:03 AM »
I have a couple of SL175's and a CH150 left to restore. The CH150 ran when I put it up this winter, but after cleaning the carb, new battery, still won't start.
Has spark. Even w/ dumping starter fluid in carb, no go. ???? I'm at a lost.
michel
PS thanks I'll check out t;he links.
« Reply #4 on: June 04, 2020, 09:42:25 AM »
michel
Michel,
I've worked on those Honda CH150 scooters before,watercooled.The first thing I would do now,after you've checked for spark,completely cleaned all(including remove the pilot jet and clean it)passages in the carb.,check and adjust the valve clearances(.002" I think,check the sticker on the frame)as those get fairly hot and the valves can stick open a bit,etc.
Offline 74cb750
« Reply #5 on: June 05, 2020, 05:44:44 AM »
Ok, I haven't checked the valve clearances....at this point I'll try anything. I'm thinking the gas lines are improperly set. Michel
Online carnivorous chicken
« Reply #6 on: June 05, 2020, 08:43:43 AM »
https://www.vintagehondatwins.com/forums/forum.php is another -- it's up and running and attracting people from the Honda twins site who are over the ads and policies.
Offline Alan F.
« Reply #7 on: June 05, 2020, 09:57:10 AM »
« Reply #8 on: June 05, 2020, 11:03:44 AM »
You mean the vacuum petcock? Yeah,would suck if someone hooked up the fuel line to the intake manifold vacuum port.
« Reply #9 on: June 19, 2020, 06:37:06 PM »
michel
Try running a points file thru the points. They sometimes (often) rusted on the older bikes that did not have tungsten points. They often had simple steel contacts.
