Author Topic: The Alma Build  (Read 11671 times)
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #50 on: August 07, 2020, 12:39:48 PM »
SHE LIVES!!!
Attempted to start her yesterday morning....that was a joke.  That 96" engine needs a REAL GOOD battery, it wasn't full but was blinking green....lol.  When it hit compression the starter just stalled, another 2 hours on the charger and she fired right off.
The engine sounds great, no noises or smoke, and after a little fussin with the carb she settled into a nice "potato-potato" cadence at 750 rpm.  I have a light click or knock in the primary around the clutch basket area so that has to come back apart for some lookin.
The Badlands module that came with the switches that was in "working" condition was garbage....I HATE LIARS! New one shipped today so my blinkers should be in working order next week.   All in all I'm pretty stoked with her, gotta get that noise figured though, I wanta go for a ride.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #51 on: August 07, 2020, 01:09:45 PM »
I have a turn signal cancel module from badlands got my fronts working but the wiring diagram sucks that came with it
1978 CB 750K ard and webers
another anfob
Offline Alan F.
Re: The Alma Build
« Reply #52 on: August 07, 2020, 08:27:44 PM »
That's great news! Best of luck on an easy ID/fix once you get a look in the clutch area.
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #53 on: August 08, 2020, 09:49:39 AM »
Yes, yes it does....lol.  I had to find one on the internet.
Shouldn't be a big deal (I hope) it didn't make any noise before it came apart.....lol, but then it was put together wrong too.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #54 on: August 08, 2020, 03:21:34 PM »
do you have a link to that,seems like you have to ignore the stock harness
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #55 on: August 08, 2020, 09:54:04 PM »
Red               12v+
Black             Ground
Violet             Left 12v input
Brown            Right 12v input
Yellow            Right output
Grey              Left output
I just have a photo of an instruction page, but I hear that if the ground isn't good, it will blow the module.
Hope this helps
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #56 on: August 09, 2020, 04:13:14 AM »
I have tapped into the input wires,I think this still makes use of the stock wiring ,I think I have to just take the input wires to the module,instead of tapping into the wire?
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #57 on: August 09, 2020, 09:49:58 AM »
I think the main issue with a SOHC is that the flasher is before the switch, where as on an HD it's after, cause there were required to have hazards.
If you wire out the flasher, it should be pretty easy from there.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #58 on: August 09, 2020, 11:35:26 AM »
this is on a sportster
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #59 on: August 10, 2020, 10:30:38 AM »
What year?  Should be pretty straight forward, HD's wiring is pretty simple.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #60 on: August 10, 2020, 05:53:32 PM »
88,think I have it solved,got the right side working front and back,then wired up the left,all 4 started blinking leading me to think I have a common wire ,my front lights are 3 wire so maybe have a ground mixed up
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #61 on: August 11, 2020, 12:27:31 PM »
That's possible, not real hip on Sportsters.  Mine has no ground on the front blinkers, it's done through the housing.
11 Ranger S/C 2wd
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #62 on: August 11, 2020, 12:33:05 PM »
Got my new Badlands module and installed it today.....YEAH, I have blinkers again.  Still need to sort out the noise in the clutch area and plan on getting started on that today.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #63 on: August 11, 2020, 02:07:08 PM »
did you wire out the flasher?if so how,still having issues so went back to stock
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #64 on: August 11, 2020, 09:26:52 PM »
Yes you have to, my 87 had 2 flashers.  1 for the blinkers and 1 for the 4-way.  I don't have a wire diag for a sporty, but let me do a little research....I'll get back to ya.   ;D
11 Ranger S/C 2wd
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #65 on: August 11, 2020, 09:38:06 PM »
Figured it out.....your dash directional indicator is screwing you.....lol.  It get it's power from the switch that's activated and gets the ground from the other one that's not.  It's doable but there's a bit of rewiring to be done.  If you want to go farther.....I'll give you a blow by blow on how.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #66 on: August 12, 2020, 05:51:04 AM »
yes it flashes when either signal is pushed,and the flasher is tied to both sides,so it seems with stock wiring you cant wire them independent of each other,like the badlands diagram.pm me with your solution,my wiring has not been played with,you have a real nice bike there!bill
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #67 on: August 12, 2020, 09:40:34 AM »
I'll get a "plan-o-gram" together today for ya, you'll need a couple of diodes for the indicator to still work also.   Is your Badlands module the newer one with Orange as 12v+?  The new one I got was Orange, the old one that was trash was Red.
11 Ranger S/C 2wd
Offline BPellerine
Re: The Alma Build
« Reply #68 on: August 12, 2020, 12:13:53 PM »
mine has the orange wire with the fuse inline,looks like I can hide everything in the tins up front now with your info,thanks
another anfob
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #69 on: August 12, 2020, 03:40:28 PM »
no problem....wiring is my thing.
11 Ranger S/C 2wd
Offline Alan F.
Re: The Alma Build
« Reply #70 on: September 06, 2020, 10:37:00 AM »
Hey Brother, how's this project working out? I hope all is well and you're riding instead of typing.
Last I knew you had a new noise in the clutch somewhere but then started talking about wiring directional....
Oh Jeez, still hot out huh? https://forecast.weather.gov/MapClick.php?lat=33.685&lon=-117.1539#.X1UeX_kpCyU
Up here it's getting cooler but I've just changed jobs and when I'm not on call I just want to be as lazy as possible, no progress on my bikes to report.
« Last Edit: September 06, 2020, 10:40:46 AM by Alan F. »
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #71 on: September 11, 2020, 06:21:15 PM »
Between my MIL, the heat, ash storms, fires, and horrific air quality.....today wasn't to bad.   I finally got to do an "extended" run session today.  Let her run for 20 minutes with a fan.  I have to say that this is the nosiest engine cold that I've ever owned.
the results........
11 Ranger S/C 2wd
Offline Alan F.
Re: The Alma Build
« Reply #72 on: September 11, 2020, 07:17:21 PM »
Good news in that video! How'd the test ride go?
Offline Desert-SOHC
  • It's old
Re: The Alma Build
« Reply #73 on: September 12, 2020, 01:09:26 PM »
haven't been able to get out......with the smoke and ash storms.  Hopefully it will clear up soon.
11 Ranger S/C 2wd
Offline Alan F.
Re: The Alma Build
« Reply #74 on: September 12, 2020, 01:23:12 PM »
It's always something to keep us from doing what we most want to, isn't it?
Bike looks and sounds good and strong, you've done a heck of a job.
