Author Topic: cr specials  (Read 1944 times)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
cr specials
« on: June 07, 2020, 10:10:40 AM »
Anyone running these on a cb750?  Can you tell me what is missing from this threaded hole on one side of this carb?
Notice the carb beside it is not threaded on the same spot.
Here is what the other side of this carb looks like.
Offline FJ40toy
Re: cr specials
« Reply #1 on: June 07, 2020, 10:46:32 AM »
That is the idle air screw. The carbs are cast with the ability to have it on either side, depending on how it is going to be configured.
Sent from my moto z3 using Tapatalk
1978 CB750F, 1973 XL250 Motosport, 1982 FT500 Ascot(engine rebuild), 2000 VTR1000F Superhawk, 1974 CB550 (waiting for rebuild)
  • Gusto mo titi ko?
    • project
Re: cr specials
« Reply #2 on: June 07, 2020, 12:26:59 PM »
Do i need one on both sides? That is the other 3 are only threaded on 1 side.  ‘Preciate your help!
Offline FJ40toy
Re: cr specials
« Reply #3 on: June 07, 2020, 01:04:29 PM »
You don't need one on each side. Cylinders 1 and 2 have the air screws on the left side of the carb. Cylinders 3 and 4 have the air screws on the right side of the carb. Makes it easier to adjust them.
  • Gusto mo titi ko?
    • project
Re: cr specials
« Reply #4 on: June 07, 2020, 01:27:24 PM »
So it ok for that one to be ooen to the atmos, right?
Offline FJ40toy
Re: cr specials
« Reply #5 on: June 07, 2020, 01:39:04 PM »
No, it needs an adjustment screw like the rest. JetsRus has parts if you need them.
https://www.jetsrus.com/carburetor/carb_keihin_CR_special_carb_exploded_view_parts.html
  • Gusto mo titi ko?
    • project
Re: cr specials
« Reply #6 on: June 07, 2020, 01:51:25 PM »
Hmmm, this carb has 1 on each side. Do i cap it off, or run 2 adjustment screws?
Offline FJ40toy
Re: cr specials
« Reply #7 on: June 07, 2020, 02:15:25 PM »
That's odd. Typically they only have one. Maybe the previous owner drilled and taped the other hole?
The CRs I have on my 750 only have one per carb. You'll have to investigate if that second air screw hole goes into the carb body. You can spray some carb cleaner or WD40 to see if it comes out the bypass port on the back side, the engine side of the carb.
The photo is carbs 3 and 4 on mine. The air screws are towards the outside of the carb. If the second screw hole on yours is on the inside, I would put a screw in it to just plug it.
  • Gusto mo titi ko?
    • project
cr specials
« Reply #8 on: June 07, 2020, 02:34:51 PM »
Yeah, that was the reason for my post. That carb has one on both sides, and i did shoot carb cleaner into it.
Here is a top view of carb 3. You can visualize what i am talking about.
Here is the questionable adjustment screw hole on the same carb.
« Last Edit: June 07, 2020, 02:43:34 PM by Medyo Bastos »
Offline FJ40toy
Re: cr specials
« Reply #9 on: June 07, 2020, 02:58:52 PM »
Ok. I think a previous owner drilled and taped it. When you sprayed carb cleaner did it go any where? If not, you can leave like it is or put a screw in it just to keep and dirt out.
Re: cr specials
« Reply #10 on: June 07, 2020, 06:02:21 PM »
Correct....the bodies are mirror imaged. If it makes you feel better plug it but it won;'t make a difference.
Offline azuredesign
  • Knupping pin
Re: cr specials
« Reply #11 on: June 12, 2020, 09:45:33 AM »
I had the same issue, and believe that both sides are tapped before one side received a screw, and the other side a plug. I found a suitably threaded screw and closed off the open side that should have had a plug.
Offline todd.s.holloway
    • 1975 Honda CB750F
Re: cr specials
« Reply #12 on: June 13, 2020, 10:09:29 PM »
Does anyone who uses these on a cb750 see an improvement in power? Or longevity/reliability of tuning?
Sent from my SM-G950F using Tapatalk
Offline bear
  • Leeton in Australia
Re: cr specials
« Reply #13 on: June 14, 2020, 05:02:43 AM »
I have used CR33's on my CB750 sohc based historic road racing sidecar for many years.
These carbs are 70's era competition technology and they work very well for that purpose.
But they have a rudimentary low speed circuit and can sometimes cause a small hesitation at low rpms.
I would be very surprised if there are not better alternatives these days.
    • 1975 Honda CB750F
Re: cr specials
« Reply #14 on: June 14, 2020, 10:07:57 AM »
So it sounds like theyre a bit gurgly/stally at low revs? Other than that, you see a performance enhancement?
How do you fit them on to a 1975 cb750 sohc?
These were made stock for the dohc bikes later right? I like upgrades that are also period-ish correct and by the manufacturer!
Offline bear
Re: cr specials
« Reply #15 on: June 14, 2020, 06:10:51 PM »
They come on a bank (aka rack). Their spacing can be adjusted to suit the intake your fitting them to.
Appropriate spigots are available to allow fitment to the Honda's std manifolds for the CR 29s and 31s.
No. Keihin CR carbs are an aftermarket competition carburetor.
I do not believe these carburetors are a worthwhile "performance enhancement" on a sohc road bike.
They are not a plug and play option in my opinion.
Brian
Offline cb550fcafe
    • KDI Cycles
Re: cr specials
« Reply #16 on: June 15, 2020, 11:05:07 AM »
that screw hole is to retain a bracket for different spacing. On certain spacing requirements the two center carbs are far apart an the fuel "T" could slide out. There is a bracket that holds the "T" and uses the screw hole.
