Author Topic: First time starting new engine, 2 & 3 not as hot  (Read 3648 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: First time starting new engine, 2 & 3 not as hot
« Reply #25 on: June 15, 2020, 03:01:18 PM »
When I experienced symptoms like yours the issue was ignition. On my old 550 it was a failing electronic ignition. On my 750 it only went away when I disassembled my 2-3 points, dressed the surface of the points with a file and made sure that all insulator washers and sleeves were properly installed.
Offline jakec
« Reply #26 on: June 15, 2020, 03:08:49 PM »
I have checked the insulator washers, as well as cleaning the points with fine sand paper. It is entirely possible that it is the points,since this problem seemed exist the same before rebuild.. But checking points over and over I don't see anything wrong with them.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #27 on: June 15, 2020, 06:27:30 PM »
I just ran it again after adjusting air screws, checking points, ensuring fuel flow, new plugs on 2 & 3.
Ugh!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
« Reply #28 on: June 16, 2020, 08:14:50 AM »
Have you checked the 2+3 plugcaps (resistance)?
You can check them like this. Start with checking the total resistance from one plugcap via the coil to the other plugcap. Realise that new resistor plugcaps are around 5kΩ each. The coils secundary itself is around 14-15kΩ, so with both plugcaps attached, you should read 24-30kΩ in total. When you read over 30kΩ in total, unscrew both plugcaps to be tested individually. Over time the plugcaps resistance tends to increase. When over 8kΩ, replace. Do not run and resistor caps and resistor plugs. When you have the choice, I'd prefer resistor caps over resistor plugs. Verify plugcaps are firmly connected to the wires.
Is by accident condenser 2+3's forked connector on the wrong side of the brown insulator ring? Any arcing at the 2+3 breakerpoints? Here's a vid showing a good and a bad condenser. Condenser 1+4 is bad, 2+3 is good.
« Last Edit: June 16, 2020, 08:34:38 AM by Deltarider »
CB500K2-ED Excel black
Offline jakec
« Reply #29 on: June 16, 2020, 10:42:11 AM »
Thanks for the response. The spark plug caps are new, would testing them also be testing the coils? Coils are stock and I am using NGK 5 ohm resistance coils. I am not sure what type of plugs they are, they just the manual specified D8ea plugs.
I watched the bike run with points cover off yesterday and it seemed that the points weren't arcing at all, or maybe just a little (like right side 2.3 in the video). When I was setting the timing the 1.4 was arcing a bit too much but that was corrected when I set the points gap and cleaned the contacts with sand paper. I will check the condenser fork asap.
I am considering buying new coils and an electronic ignition, as well as taking out carbs to inspect while I wait for parts to arrive. There is a ride on the 28th I would like to attend.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
« Reply #30 on: June 16, 2020, 11:15:03 AM »
A little sparking at the breakerpoints is normal. 'Buying stuff' is not the solution (its a serious addiction in some societies), diagnosing is! The coils are rarely the problem!
Offline jakec
« Reply #31 on: June 16, 2020, 11:44:09 AM »
I agree, I'm not in a big hurry to spend $200 although I feel like I'm exhausting my options.
I just checked and both condensers are connected the same way, with washers separating the forks from the post that connects to the points plate.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
« Reply #32 on: June 16, 2020, 11:54:25 AM »
The plugs are the D8EA type which is good, the 2nd from the right might have its electrode bent too close to the center electrode. I'd check that. The gap should be 0,7 mm.
Without having read all the above, have you tried swapping the coils to see if the problem follows?
Offline jakec
« Reply #33 on: June 16, 2020, 12:26:11 PM »
I don't have any extra coils, and the leads aren't long enough to swap the 2.3 into the 1.4 position. Although that would be a great idea.
Is it possible that a bad coil can fire some of the time?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Robbo
« Reply #34 on: June 16, 2020, 02:09:48 PM »
Have you tried swapping the condensers?  If the problem moves from 2-3 to 1-4, I would replace the bad condenser.
If the problem remains with the 2-3, at least you have eliminated a bad condenser as a possibility.
1973 CB350 Four, 1975 CB550K
Offline jakec
« Reply #35 on: June 16, 2020, 02:27:08 PM »
I had already tested the condensers separately and they behaved the same. I could certainly swap them but they aren't looking anything like the bad one in the video.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Robbo
« Reply #36 on: June 16, 2020, 02:50:25 PM »
It’s something I would do personally and it is a quick and easy task.  I’d also re-check my valve clearances and do a compression test.
Regarding the carb air screw setting, I have my 350f carbs at 1 turn out from lightly seated.  I believe you said yours are set at 1 3/4 turns.  I would be worried that they might be set too lean.  Have you tried them at other settings?  Turning them in will make it richer.  I would be tempted to try setting them at 1 1/2 or at 1 1/4 turns out from lightly seated.
Offline jakec
« Reply #37 on: June 16, 2020, 07:26:58 PM »
Just removed carbs, all had plenty of gas in the bowl and once they were drained I looked inside. Nothing to note inside except 3 & 4 float height is a little higher because the springs inside the needle valves are weak. They weren’t leaking though. I also confirmed the jet sizes and that they aren’t clogged. Finally I checked the bench sync which seems adequate. I think I can rule out a problem with the carbs.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #38 on: June 16, 2020, 07:40:10 PM »
I also removed the points and advancer, which both look fine. The advancer shaft does not appear bent and neither does the bolt that holds in. The advance springs are strong and the arms snap back nicely.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Online scottly
« Reply #39 on: June 16, 2020, 08:16:54 PM »
I just rebuilt carbs and corrected float level. Unless you mean to do the clear tube method.
Ignition can't carbon foul spark plugs; you have a carburetor problem. Verify the fuel levels in the float bowls as Alan suggested, using the clear tube method. This can be done with the carbs mounted on the bike.
Offline jakec
« Reply #40 on: June 16, 2020, 08:53:22 PM »
I thought that maybe the fouling occurred if the cylinders were only sparking correctly say 1/2 the time.. then each combustion would have double fuel. I did buy clear tube and plan to do a tube test while the carbs are out.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Scott S
« Reply #41 on: June 17, 2020, 02:52:38 AM »
I would like to do that now but there are two things stopping me, 1. don't have a single line long enough, and 2. it's pretty much impossible to install a line on the carbs when in frame.
  Now that the carbs are out again, install the proper 5.5mm fuel line in the correct length and get rid of the external filter. Fit the line to the carbs BEFORE installation and then attach it to the petcock, not vice versa.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Alan F.
« Reply #42 on: June 17, 2020, 05:17:59 AM »
Could this now be a matter of independently setting air screw positions for each carb?
Or is that too off the wall and will add to the confusion?
Offline Deltarider
« Reply #43 on: June 17, 2020, 05:22:30 AM »
Good question. According to p.95 in the Honda Shop Manual the CB400F air screw openings are supposed to be at 2±1/2 turns out. http://www.honda4fun.com/pdf_man_officina/pdf_manuali/CB350-400/CB350-400_09.pdf
Offline jakec
« Reply #44 on: June 17, 2020, 08:56:38 AM »
Yeah I had installed all lines before inserting the carbs, including vents and drains. 4into1 Is all out of 5.5mm ID hose so I got some 5.3mm. I also ordrered new coils and ignition. I have some clear tube for the carbs now. So I'll try and sort out the carbs before the other stuff gets here.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #45 on: June 17, 2020, 11:33:32 AM »
I think I will also replace the main jet O rings while I can, they seem fine but I just read a post from mark saying if you have bad O rings gas can slip by on the outside dumping tons of gas into the mixture.. sounds familiar. Anyone know the hardware store O ring #?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Alan F.
« Reply #46 on: June 17, 2020, 11:41:05 AM »
The Harbor Freight metric o-ring kit is handy for things like this. It's about $8 and they are fuel resistant.
Offline jakec
« Reply #47 on: June 17, 2020, 11:45:24 AM »
We don't have a harbor freight here, it's a blessing and a curse!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #48 on: June 17, 2020, 12:21:19 PM »
Those O rings are a none standard bastard size that not even a lot of hydraulic people keep.
Somewhere on here is a post with all the carb O ring sizes in it i wrote some time ago. My books aint handy so i cant redo them
Offline jakec
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
