Author Topic: First time starting new engine, 2 & 3 not as hot  (Read 3654 times)
Offline jakec
Re: First time starting new engine, 2 & 3 not as hot
« Reply #50 on: June 17, 2020, 01:27:30 PM »
Based on facebook page suggestion I am going to check my valves again.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Alan F.
« Reply #51 on: June 17, 2020, 02:32:02 PM »
I’d also re-check my valve clearances...
Facebook huh.
Offline jakec
« Reply #52 on: June 17, 2020, 04:11:14 PM »
Yeah there is a really active facebook page for the 400.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #53 on: June 17, 2020, 07:27:24 PM »
Have you done a compression test that shows low values?
Offline Alan F.
« Reply #54 on: June 17, 2020, 07:49:28 PM »
I’d also re-check my valve clearances and do a compression test.
More of the quote I quoted earlier.
« Reply #55 on: June 18, 2020, 03:17:59 AM »
Have a close look at the O-rings around the main jets. They are often overlooked...
Offline jakec
« Reply #56 on: June 18, 2020, 09:11:22 AM »
Yeah I have checked the O rings and they appear to be ok but I have thought about replacing. Also No I do not have a compression tester.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Alan F.
« Last Edit: June 18, 2020, 09:45:46 AM by Alan F. »
Offline jakec
« Reply #58 on: June 18, 2020, 11:26:30 AM »
How do you know where I live!!! Really though those are all over 30 minutes away. But I have ordered the O rings as of this morning!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Bankerdanny
  • Endeavor to persevere
« Reply #59 on: June 18, 2020, 11:27:14 AM »
I don't have any extra coils, and the leads aren't long enough to swap the 2.3 into the 1.4 position. Although that would be a great idea.
Is it possible that a bad coil can fire some of the time?
Since you know the 1-4 side of the ignition is working you don't need to swap the coils to test the 2-3. Unplug the yellow and blue wires at the coils. Plug the blue wire from the harness to the yellow one to the coil. Pull the 2 or 3 ignition wire and insert a spare plug. Turn on the ignition, touch the plug to the valve cover or a barrel fin and hit the starter button. If the coil is the issue then you still won't have spark. If you do see a spark then the problem is likely not the coil and is somewhere else in your system.
Offline jakec
« Reply #60 on: June 19, 2020, 08:14:36 PM »
Have a friend visiting now so harder to work on the bike. But I have replaced main jet O rings, check float level with clear tube, and checked valves. Adjusted #2 exhaust a little bit. Now waiting for coils and stuff to come tomorrow, and I will install and try to start again.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #61 on: June 21, 2020, 10:44:12 PM »
So it's fixed now? What was wrong?
Offline jakec
« Reply #62 on: June 22, 2020, 09:11:57 AM »
It's hard to tell what the real problem was since I replaced coils, ignition, and re-checked the carbs (added new main jet O rings) all at the same time.
I should have swapped in just coils first to see if I could forego the new ignition, but you have to take the carbs off to access the wires to install the ignition. And the Dyna looked pretty so I said screw it and installed it. I'm leaning toward the problem being coils since that seems to line up with the inconsistent lean/rich condition on each set of paired cylinders.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
