Support the site. Your contributions keep this site running.
Quote from: AlekStooge on June 24, 2020, 06:52:07 PMOk, good. Since I'm waiting for the coils. I have a question about the stator wires. I saw the three yellow wires broke, I must have put the alternator cover on over them by accident. What does each one of those 5 wires (total) do?Those are your 3 phases of A/C current. They connect to your RR and get converted to DC and the voltage is set or "regulated" there as well. The other two wires are ground and voltage sense I found this in the forums but can't remember where, Sent from my SM-N950U1 using Tapatalkhttp://cloud.tapatalk.com/s/5ef4098e22972/SB3PhaseCharging%20%281%29.pdf
Dude, you mashed the 3 stator wires ( Y,Y,Y ) under the alternator cover and cut them in two ! = no charge, own that. Now get an OEM points plate and 5 ohm coils and set 'em up. I ya want to ride yer bike that is . Good luck.
Your anemic 550 charging will not support electronic ignition, but do as you please or ride your bike !
There is no room for connectors at the stator and ive never seen a manufacturers soldered joint fail.Electronic ignition is fitted by people who want to do long journeys and are not good at setting points gaps and timing.If you ride at consistently high revs it can just about cope, same as H4 headlamp do both and you are on a hiding to nothing
Of course it arcs its drawing 180+amps.The plug is to block the end of a macined gallery, you have to have access for machine tools, it cant be done by majic!
Instantaneous current yes, about 60 when running.How else would you think a hole would appear in a casting
