Author Topic: 550 LH Switch Inner replacement screw size - SOLVED  (Read 650 times)
Offline Bristledisk
« on: June 26, 2020, 01:16:15 PM »
Hi All, I'm rebuild the inners of the switch and need to replace some of the small screws that hold the brackets inside the switch e.g. holding in the light switch and horn button. What size are those small screws? Thanks
Just in case anyone else is looking, I tried a few screws from the garage and the correct screws are 3 x 6. I found some 3 x  25 screws that I think we part of the back light assembly or maybe from another switch. I'll be cut these down to size. Also the carburettor butterfly assembly screws are 3 x 10 but not counter sunk.
In the attached photo, the smallest screw on the right, is the one I'm trying to replace.
« Last Edit: June 27, 2020, 11:32:50 AM by Bristledisk »
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Re: 550 LH Switch Inner replacement screw size
« Reply #1 on: June 26, 2020, 11:32:32 PM »
Simple answer is 'kin tiny and dont know.
I think they may be some type of self tapper but not 100% on that
