What did that sound like, it may have beaten the hole oval as it came out.
No such thing as a rebuild kit. Gasket kits now tend to be complete engine and you probably need a new cam cover, all 500/550 from 71 to 78 will fit but up to 76 can wear the spindle holes whilst 77 and 78 were modifield.
Stick the rocker shaft part way and give it a wiggle and tell us what happens.
Nope cam cover and valve(s) maybe
I'd be worried about that cam lobe, too. If the rocker is off the shaft and the cam is trying to lift the rocker, what is happening in there? Beating it around?
You may not be that bad off...I have seen caps damaged worse from just the nut coming loose. Remember, a rocker without a shaft probably isnt going to open a valve...unless some sort of freak jam up happened.
Fack that was 7 seconds ..?..a new 500 rocker cover removal record !
Cam top left pic, looks like edge pushed over , makes nothing will come of easy. , some wear on the hard fave on the side of rocker, but if you mainly want to get thrubthe season it looks like you can use it, better than I expected
It happened cos the end cap fell off. Was the screw missing or broken, if missing not toght enough.Remember the soft alloy washer between the steel bracket and cam cover or you will have an oil leak.I would reuse all of that, you cant make it worse
