Author Topic: White smoke from exhaust/breather, good compression, lean?  (Read 3428 times)
Offline Erny
Re: White smoke from exhaust/breather, good compression, lean?
« Reply #25 on: August 19, 2020, 03:40:08 PM »
I've read some thread that advancer might need lubrication (can be yoir case) - did you try? Look into service manual for details what to lubricate.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline jorwesflow
  • we're not schizophrenic
« Reply #26 on: August 19, 2020, 10:40:00 PM »
Yeah I know you're supposed to put a little grease on the advancer shaft, which I did with some white lithium grease because it was within reach.
Maybe there's something else that needs grease?
1977 CB550K
Offline BenelliSEI
  • 1969 cb750
« Reply #27 on: August 20, 2020, 05:14:03 AM »
Just grab the advancer and advance it by hand (engine stopped!). It only moves a small amount, but should be free and nonsticking. If it isn’t you can remove everything, clean polish shaft and hub, few drops of oil and reassemble. It’s a pain, b cause the points/ plate has to come off, then you start over.
Offline markreimer
« Reply #28 on: August 20, 2020, 08:48:29 AM »
I wonder if your grease is too thick and the advance isn’t moving freely. It should be a very light and small amount of oil. On my GL1000 it actually says not to use any oil as it can be too sticky and affect the advance. I used a drop or two of triflow oil after a thorough clean and polish. It has a nice linear and smooth motion now
