Author Topic: Excessive brake pad dust and pad rubbing?  (Read 4904 times)
Offline Pielz
Re: Excessive brake pad dust and pad rubbing?
« Reply #25 on: July 08, 2020, 08:44:45 PM »
How would I remedy that? Buying a smaller wheel?
A lower profile tire;is that tire what they run on the DOHC donor bike front ?
The DOHC runs a 100/100 19" it seems
« Reply #26 on: July 08, 2020, 08:48:18 PM »
Look at the tire for signs of rubbing, like shiny areas. Pay attention to the sides where the fender stays are.
Offline Pielz
« Reply #27 on: July 08, 2020, 08:51:03 PM »
Will do!
« Reply #28 on: July 08, 2020, 08:51:31 PM »
Collect some black dust and burn it, feel the smell. Rubber?
Offline Pielz
« Reply #29 on: July 08, 2020, 08:52:33 PM »
Good idea!! Here's a pic so you can see what I mean
« Reply #30 on: July 08, 2020, 08:55:04 PM »
That's not from brake pads!!!!
Offline Pielz
« Reply #31 on: July 08, 2020, 08:56:40 PM »
Yeah honestly now that I look at it again I feel kinda silly thinking it was
« Reply #32 on: July 08, 2020, 09:10:11 PM »
Aren't you glad you didn't rush to buy a new master cylinder? ;D
Offline Pielz
« Reply #33 on: July 08, 2020, 09:12:09 PM »
I am! My cheap Chinese perch will live to see another day! Haha.
While you're here I should ask, when I pull the front brake, it sorta pulses? Is that a warped rotor? It stops fine but I can feel the lever sorta moving in my hand.
Brake action is smooth though. Braking power doesn't pulse
« Reply #34 on: July 08, 2020, 09:19:36 PM »
Could be a warped rotor, or maybe it's from the tire rubbing? ???
hill29493
« Reply #35 on: July 08, 2020, 09:29:05 PM »
I'd say your single disk is not strong enough
Hell
Offline Pielz
« Reply #36 on: July 08, 2020, 09:35:10 PM »
It's gotta be one or the other I guess. Maybe some day I'll do a front end swap from a 750F so I can go dual disk. For now at least I have some things to check. I'll use an index like a paper clip taped to the fork to try to gauge if the rotor is wobbly. And try to inspect for rub marks. I'll update!
hill29493
« Reply #37 on: July 08, 2020, 09:40:08 PM »
If your bike had duel discs it's for a reason my friend I'm a bit stuck trying to find duel discs in UK for the front end of mine the problem is the bolts go through the wheel and hold both discs togeether I can find single disc in UK burn it not go intnl to be strong enough
Hell
Offline Pielz
« Reply #38 on: July 08, 2020, 09:45:50 PM »
My bike is a K to begin with so it never had dual disks. Would certainly be nice if it did though. Hope you find some on your quest! If I liked the way it looked and didn't care about period correctness, I'd do the GSX front swap I've seen folks do lol
hill29493
« Reply #39 on: July 08, 2020, 09:47:50 PM »
It might not even be your brakes tbh you might not have a proper seal on your manifold
Hell
hill29493
« Reply #40 on: July 08, 2020, 09:49:35 PM »
Sound like you need new exhaust gaskets
Hell
hill29493
« Reply #41 on: July 08, 2020, 09:52:10 PM »
I would of done the same but wanted to keep the style of fork so I put a 750fa front end on my francenstin cb
Hell
Offline Pielz
« Reply #42 on: July 08, 2020, 09:52:14 PM »
I just installed a delkevic 4into1 with new gaskets. I guess its possible I messed up but I don't feel any puffs of exhaust by the head. Also the black powder just brushes off. It doesn't smear which I guess now that I think about it, should have tipped me off to it being rubber not brakes.
Post a pic of your Frankenstein!
hill29493
« Reply #43 on: July 08, 2020, 09:58:50 PM »
You might just wanted to check if your manifold is not to small. Iv ordered a 4in1 for a cb900 for a 650 port which I need to michean down to fit the ports hopefully I'll find out when thay come if not it a nice way to waist £499
Hell
hill29493
« Reply #44 on: July 08, 2020, 10:01:48 PM »
Here's franckie
Hell
hill29493
« Reply #45 on: July 08, 2020, 10:03:01 PM »
Well there you go its tyre dust or something of the road
Hell
Offline Pielz
« Reply #46 on: July 08, 2020, 10:04:00 PM »
That is definitely a Frankenstein!
What's the headlight shroud from?
hill29493
« Reply #47 on: July 08, 2020, 10:05:41 PM »
It a universal one there 13$on ebay
Hell
hill29493
« Reply #48 on: July 08, 2020, 10:08:13 PM »
I didn't like original levers so I put these on
Hell
« Reply #49 on: July 08, 2020, 10:40:50 PM »
That's a nice blue color.
