Author Topic: Excessive brake pad dust and pad rubbing?  (Read 7519 times)
Re: Excessive brake pad dust and pad rubbing?
« Reply #50 on: July 08, 2020, 10:44:06 PM »
There's people that talk behind to ur back on here mate what who you talk you
Hell
Oh ?
Offline Pielz
« Reply #51 on: July 08, 2020, 10:53:52 PM »
I'm sorry folks are not being very friendly. I don't know the circumstances so I wont comment on anything but I just hope everyone can get along one way or another
« Reply #52 on: July 08, 2020, 11:24:51 PM »
I think when people here learn to trust a new member it will become better.
« Reply #53 on: July 09, 2020, 07:50:10 AM »
 On to a different topic did we determine that its rubber dust all over your bike and pant leg ? I like what you have done to your bike by the way  ;) Those front brakes are definitely more modern.
Offline Pielz
« Reply #54 on: July 09, 2020, 09:03:53 AM »
Thank you! Yeah it definitely tire lol. still have to go out and examine exactly where it's rubbing. And my front forks and brake are from a ~1981 CB750k. That much I've determined. Which might not be such a bad thing as I've heard the gen 1 brakes are pretty bad
« Reply #55 on: July 09, 2020, 09:57:06 AM »
Hi Brent,The complete front-end is from the DOHC bike including wheel,brakes and fender ?
Offline Pielz
« Reply #56 on: July 09, 2020, 10:16:37 AM »
The original wheels were spoked but these comstars came from a similar year so they were a direct bolt on replacement. All the hardware was the same including axles, spacers, brake size, etc.
« Reply #57 on: July 09, 2020, 10:32:50 AM »
What size is stamped into your front wheel ?
Offline Pielz
« Reply #58 on: July 09, 2020, 10:47:22 AM »
1.85x19 is stamped in to the wheel. Also I think I can see where the tire** is rubbing on some part of the fender. It's on the left third of the tire** tread and about as thick as the tip of a highlighter. I'll have to look closer when it's not so oppressively hot outside. It's like stepping in to a sauna over here
« Last Edit: July 09, 2020, 11:26:47 AM by Pielz »
Offline Pielz
« Reply #59 on: July 09, 2020, 10:53:47 AM »
The tire** that was on it when I got it was a 110/90 19 so I just put that on again. I guess the tread on the shinko I have is thicker or different than whatever was on it before. Maybe increasing the air pressure a bit would bring the edges in and make it stop rubbing. Who knows
« Last Edit: July 09, 2020, 11:24:37 AM by Pielz »
« Reply #60 on: July 09, 2020, 11:06:57 AM »
The wheel that was on it when I got it was a 110/90 19 so I just put that on again. I guess the tread on the shinko I have is thicker or different than whatever was on it before. Maybe increasing the air pressure a bit would bring the edges in and make it stop rubbing. Who knows
No.
I am asking you about the comstar wheel on the front of your CB750K7 right now.The wheel has numbers of what size it is stamped into the wheel.
« Reply #61 on: July 09, 2020, 11:15:09 AM »
You have to make the distinction between wheel, which is the metal round thing fastened to the forks and tyre which is the roundish rubber thing on the wheel
Offline Pielz
« Reply #62 on: July 09, 2020, 11:26:10 AM »
Sorry guys, I wasn't thinking lol. I fixed my previous 2 comments to be a little more clear. I always mess that up. I know the distinction but it's like slipping up and calling a bolt a nut or vice versa. I do it all the time
« Reply #63 on: July 09, 2020, 11:31:07 AM »
Okay  :) 1.85x19,got it.I wouldn't use any tire on that larger than what's recommended.I think a 100/90x19 would be a good fit,imo.
