Author Topic: 73 cb500 no spark  (Read 727 times)
Offline djoz371
73 cb500 no spark
« on: July 10, 2020, 12:55:45 PM »
Hello all. Here is the deal. 1973 CB500 gift from the wife a couple years ago. Not to much ride time on it. I start and ride it around the block once every few months. Tried to start recently with no luck. I have no spark. I have ruled out the kill switch (power to the black & white at the coils). It has DYNA ignition system that looks pretty new. I am pretty unfamiliar with the electrical on these bikes but picking a few things up. Stator looks to be in great condition. Could the coil setup be bad? It has a new battery as well. I am a newb so pretty lost on electrical. It sits in a shed when not riding so not sure what would cause the spark to just stop. Any help is very much appreciated.
Chris
1973 CB500
Re: 73 cb500 no spark
« Reply #1 on: July 10, 2020, 10:14:21 PM »
Check the power lead to the dyna, there was a spate of dynas dying and on the 500/550 they put too much load on the charging circuit
« Reply #2 on: July 11, 2020, 02:11:37 AM »
start with every and all electrical connectors,clean all those gang plugs etc,the 500 only had one fuse,be sure its intact and contacts are clean,its often a simple fix if it was running before it was parked(weve heard that one?)
Offline djoz371
« Reply #3 on: July 11, 2020, 11:58:07 AM »
Turns out that it has the 5ohm Dyna coils. They need to be disconnected to do an ohm test correct?
Chris
1973 CB500
