Author Topic: Any member with 1960s Honda C100?  (Read 2238 times)
Offline Can550
« on: July 12, 2020, 07:37:59 AM »
Would like to save this one 1965 C100. Need help with certain info and parts. Would be great to find someone who has worked on one.
Thanks
Offline jlh3rd
Re: Any member with 1960s Honda C100?
« Reply #1 on: July 12, 2020, 01:26:54 PM »
try robin markey here....
Offline Bodi
« Reply #2 on: July 31, 2020, 04:20:10 PM »
What's the problem, other than the missing leg guard? Really simple engine, super reliable. Brakes are puny but they work. Rocker forks work ok but limited travel.
No idea on parts availability but Honda made millions of Cubs, should still be some parts for the pushrod ones.
I had a 65 and took it apart several times.
Offline Can550
« Reply #3 on: July 31, 2020, 06:40:11 PM »
I have the leg shields which are super clean. It’s the kickstart spindle that broke off right at splines, flat with cover. Can’t put a pedal on. Was hoping to find a spindle to make it rideable
Offline Bodi
« Reply #4 on: August 01, 2020, 05:21:31 AM »
That changed a few times in production. CMSNL has most types but expensive as always. Look up the part number there for your engine number and search for it, there may be luck on ebay?
Offline Just John
  • Apparently I am a glutton for punishment
« Reply #5 on: August 03, 2020, 03:46:45 PM »
I think all the early push rod 50s used the same shaft.  Look up the part number and I bet C100-C115  will be the same.  This was a very common problem, happened to my C110 in the 60s.  I recently purchased a C110 motor with the same issue.  I found a NOS shaft on EBay.
Member
AMA Charter Life Member
AMCA
VJMCA
Offline 73hutch
« Reply #6 on: August 07, 2020, 07:36:51 PM »
I have a c100 with a broken kick spindle, I just bump start it. they motor is so small you can actually do with your hand lol
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
