Author Topic: Zinc plating the inside of a fuel tank  (Read 743 times)
Offline Alan F.
« on: July 16, 2020, 02:08:05 PM »
I've been tempted to give this a try since I learned to do DIY zinc plating a few years ago. The difficult part would be in depositing a uniform layer of zinc along the multifaceted interior of the tank.
I think I've solved that with the idea of using an array of zinc anodes (made of zinc roofing strip (sheet metal roll) commonly available at home improvement stores) housed inside of several, maybe a dozen or two Perforated Practice Golf Balls, little whiffle balls.
A short length of zinc strip attached to an insulated wire, perhaps with a styrofoam peanut or two in some of them for buoyancy, held closed with a small zip tie. It would be easy to daisy-chain these and feed them inside through the filler cap, down both sides of the interior of the tank, agitation could be performed with the help of an electric timing motor and linkage to induce 'ocean waves' into a hinged plank the tank will sit on.
Thoughts?
« Last Edit: July 16, 2020, 07:58:10 PM by Alan F. »
Re: Zinc plating the inside of a fuel tank
« Reply #1 on: July 18, 2020, 09:47:42 AM »
 That's an interesting idea, my new 69 firebird gas tank is galvanized in and out then powder coated outside.
Offline bhudders
« Reply #2 on: July 20, 2020, 09:25:15 PM »
Sounds like a good idea and it could be done without damaging the exterior paintwork, give it a try keep us informed thanks
