Ok, both wheels are 3.5 wide, and as of right now the 18" (which is what it came with) has a 140/90, which become's way too tall when mixed with the shocks I have. Enter the 16" which I have a 130/90 on it, perform's very well with my shock's. Only issue Ive ever had is with the bike leaned way over going around a hairpin turn, probably a little too fast. The 16" perform's great under everyday situation's. But it has what I believe to be the stock sprocket, which is 48 tooth, which has me turning just above 4K at 55 MPH. I do not like this. So my plan is, I'm gonna replace the bearings in the 18" paint it, and get it looking good again. Then fit it with a 140/60, or maybe smaller tire, and a 38 tooth sprocket. If that doesn't bring my cruising RPM down enough then I'll go from there, until I can get it right, and then the 18" will live in the bike. I will keep the 16" just the way it is in reserve, because I like the low end grunt it gives the bike if I'm in the mood to play. But most days I am not. This bike is actually my daily. So I wanna get the 18" into a low rev configuration..
