Author Topic: XR650L stripped carb bowl screw - how to remove?  (Read 915 times)
« on: July 25, 2020, 10:55:29 AM »
Working on the carbs off a Honda XR650L and of course one float bowl screw is stuck:
1. Using JIS screwdriver
2. Tried to drill it out - didn’t work
Now have this...
How do I get it off?
Thanks
Andy
Re: XR650L stripped carb bowl screw - how to remove?
« Reply #1 on: July 25, 2020, 11:18:21 AM »
MikeR solved it - small vice grips worked like a charm
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: July 25, 2020, 07:41:21 PM »
When that happens i usually cut a slot with a dremel cutting disc. then a impact driver with a wide bit.
Sent from my LG-G710 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Alan F.
« Reply #3 on: July 25, 2020, 09:17:42 PM »
I usually reach for these little guys, or drill the head off the screw.
https://www.channellock.com/product/424/
« Reply #4 on: July 25, 2020, 11:03:05 PM »
I replace them with socket head cap screws, so it never happens again. ;)
Offline 74cb750
« Reply #5 on: July 28, 2020, 02:13:34 AM »
this tool is also sold at Sears and I've used it many times. Works better than vise-grips as you can get closer.
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline 2wheels
« Reply #6 on: July 28, 2020, 03:19:24 PM »
dremmel rotary tool and grind the screw head off.
then the bowl should come off.
Try vice grips on the remaining screw.  Use lots of isopropy alcohol on the screw , it is a great lubricant for this but it evaporates quickly.  Lots of back and forth wiggling to let the alcohol get in.
edit. looking again you may not need to grind the head off.  but lots of alcohol really helps.  On the screw though, not drinking until the job is done.
« Last Edit: July 28, 2020, 03:27:15 PM by 2wheels »
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Steve F
« Reply #7 on: July 31, 2020, 04:56:10 PM »
Aaaaaaaaand when reassembling, use anti seize especially in zinc or alluminum.
