Author Topic: CB350 starter delete  (Read 13118 times)
chrisf
« on: February 15, 2007, 06:54:23 AM »
Hi All:
This is perhaps a dumb question, but I have to ask....
if I remove the starter on my CB/CL350, will oil puke out where the starter once was? See, I have an idea of chopping up the starter end cap and bolting it where the starter body once was. But to do so, I need to do a bit of filing/grinding. My fear is that I may not get the seal perfect, and hence oil will spill out.
--Thanks, Chris
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: CB350 starter delete
« Reply #1 on: February 15, 2007, 11:08:13 AM »
Same as the CB450's and such, you are gonna need to buy/make/fab up some sorta
block-off plate of some kind. I am sure someone makes one you can pickup, if not make your own..
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: February 15, 2007, 11:46:45 AM »
          Chris,   I'm not sure because I haven't dealt with freeze plugs in quite awhile, I'd be checking into
    seeing if a standard freezeplug or a universal freeze plug. The regular freeze plug would probably look
    better. I think the main thing would be to keep trash and water out. Or you might could get a
    machine shop make an aluminum plug for it. Of course, it you are able to make one on your own, I'd
    say go for it. As far as I know, nobody offers anything for that. Hope that helps.
                                                      Later on, Bill :) ;)
« Last Edit: February 15, 2007, 05:26:48 PM by bill440cars »
Member # 1969
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« Reply #3 on: February 15, 2007, 04:08:37 PM »
I am trying to solve this problem too. I've seen them on a site maybe M1 racing????
I've got to run now . I'll be back!
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: February 15, 2007, 09:21:08 PM »
The expanding rubber freeze plug works great. I'm thinking that I couldn't find a metal one that fit? Metal would be better, the rubber one is a bit heavy.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
chrisf
« Reply #5 on: February 16, 2007, 03:11:38 AM »
I uploaded some pictures of my idea to my website www.fiaccone.com. What do you guys think?
--Chris
Offline crazypj
  • I'm brill, me
« Reply #6 on: February 16, 2007, 08:11:50 AM »
I'm looking into making blanking plugs and also maybe a positive breather/catch tank to fit in there.
 Also  run hose from breather on cylinder head and have one way valve to lower internal engine pressure when  engines running
PJ
Offline bill440cars
« Reply #7 on: February 16, 2007, 08:56:46 AM »
PJ
             Hey PJ, Sounds cool about the plugs. On that one way valve, you mean like an automotive pcv valve? Sounds like a good idea. Keep us posted on your progress, okay?
Member # 1969
Offline crazypj
  • I'm brill, me
« Reply #8 on: February 16, 2007, 10:55:18 AM »
Hi Bill,
 I'm doing a 360 but starter end diameter is same as 350.
It will be similar to a pcv valve.
PJ
Offline CBGBs
« Reply #9 on: February 16, 2007, 04:44:01 PM »
I have come up with a quick solution. I bought a 2" pipe plug at Lowe's for about $2.60 and ground down the rubber bushing to match the diameter of the backing disk. A person could cut the carriage bolt shorter and use a nut if you wanted it to look a little nicer.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #10 on: February 17, 2007, 02:08:07 AM »
All of these starter drive are grenedes with the pin pulled. loose that #$%*e and live on the road a little longer. I have had several explode on me and I was left with only the battery to get me home.
Member#2815
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
Offline cb650
« Reply #11 on: February 17, 2007, 11:33:22 AM »
Where u guys getting the side cover gasket?
                     Terry
Offline bill440cars
« Reply #12 on: February 17, 2007, 12:43:47 PM »
                     Terry
           Hey Terry,
                       If you know the thickness of gasket paper, you could get the paper and cut your own gaskets (except of course the head gasket). I've cut gaskets, in the past, using a side cover, the paper and a very small ball peen hammer. You cut the paper to be slightly larger than the piece, use the flat end of the hammer head to to trim the gasket down to size (by lightly tapping on the outer edge of the gasket surface, which will cut through the paper, going all the way around the piece you are working on. Then trim out the inside of the gasket by lightly tapping along on the inner edge of the gasket surface). Once the gasket is cut out, then you go around to all the holes (one at a time) and, using the ball peen end of the hammer, lightly tap into each hole until the paper is cut out to leave a hole. Once you do all the holes, you will have a perfectly good gasket. It does take some practice to be able to do this without messing the gasket up and might not seem worthwhile to some. When I assembled my first streetbike, at the age of 14, my Dad sat me down with a thermostat housing from a car motor, some paper and a small ball peen hammer and told to do it until I could give him a good gasket. He and my Grandfather didn't believe in buying something, if you could make it yourself. I hope that what I've just described isn't clear as mud. ;D
Member # 1969
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #13 on: February 17, 2007, 11:46:46 PM »
Here is one I do for the 350 and 400 four.
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
chrisf
« Reply #14 on: February 18, 2007, 07:34:27 AM »
TTR400:
That is awsome! I checked out your website but could not find a price. How much is it? That will be one of the first upgrades at the end of the summer.
CBGBs:
Way to think out of the box. A stainless acorn nut would work prefectly on the end of the bolt. Here's what I ended up doing:
I updated my website and will hopefully get pics on my build log on this website.
--ATB, Chris
Offline bill440cars
« Reply #15 on: February 18, 2007, 10:36:01 AM »
                Hey, nice work there chris. That looks like a fine piece that you've created out of that starter
        end cap. 8) Should look really nice bolted in place.
Member # 1969
Offline bill440cars
« Reply #17 on: March 08, 2007, 08:44:16 AM »
      Hey Raul,  that's a pretty cool piece there. Am I wrong in my thinking, because I'm thinking that the 350 and the 450 starters have the same dimensions. I haven't really compared them all side by side but they pretty much look the same. I sent them a question about that. Thanks for posting it.  Bill :) ;)
Member # 1969
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #18 on: March 08, 2007, 04:57:13 PM »
No, that is just way too nice for a stinking old rusty Honda motorcycle?
For real;
I'm really liking that and will make one with my name on it for the next Twin 8)
Member#2815
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
Offline bill440cars
« Reply #19 on: March 08, 2007, 05:20:34 PM »
       Just for the info, I sent them a message to ask about the 450 cause I wasn't sure if they would be the same size or not and he said it's the same price. He never did say if they were the same size or not. Any way, if any one would want one for their 450/500T, here you are. ;)
« Last Edit: March 08, 2007, 05:23:06 PM by bill440cars »
Member # 1969
Offline KB02
« Reply #20 on: March 09, 2007, 05:22:03 AM »
So, I'm a little confused, is that just an oil tank in place of the old starter?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
chrisf
« Reply #21 on: March 09, 2007, 05:44:17 AM »
I've seen that machined MG plug. It is pretty cool, but I'm not real fond of the "MG" text on it. The TTr400 bit is a catch tank for crankcase breathers and carb overflows. If my cap doesn't work, I think I'll go with TTR400 bit. Nothing says "Cool bike" like craftsmanship.
--Chris
Offline bill440cars
« Reply #22 on: March 09, 2007, 06:53:05 PM »
--Chris
            You know, I agree with ya Chris, the plug looks like a cool idea but, the MG is a bit much.
Member # 1969
Offline Raul CB750K1
« Reply #23 on: March 10, 2007, 12:44:27 PM »
--Chris
¿So what? You can always put a "Live to ride" sticker over it, or ask them to sell you one without the name. I also think the engraving is out of place. It's good to do some advertising, but that's not the place.
Offline bill440cars
« Reply #24 on: March 10, 2007, 01:04:22 PM »
--Chris
              Raul, when you're right, you're right. Good point. I actually never even thought of asking them to leave the MG off. Guess I didn't figure that they would. I'll have to check that out and, even if they won't, may get one anyway, they are cool looking. 8)
Member # 1969
