Author Topic: 85 xv1000 virago starting woes.  (Read 1437 times)
Offline kerryb
  • Not a very
« on: July 29, 2020, 04:27:40 PM »
I told my friend this looked like a good bike, he bought it based on me saying we could sort out the backfiring and stalling issues.  Now I feel responsible to make good on that but it's not going well.  1985 yamaha virago xv1000.  Transistorized ignition, two hitachi cv carbs, vacuum powered fresh air system to reduce emissions.  My first mistake was thinking this would be like working on a honda of an earlier vintage, boy was I wrong!
When I got the bike it would idle poorly and backfire a lot.  The carbs sounded unbalanced, and if you opened the throttle it would die.
So far I have drained the carbs, supplied fresh gas to the fuel pump from an auxiliary tank.  Checked to see spark at both plugs (the spark will jump a 1/4" gap), checked the vacuum  lines and boots for leaks, disconnected the emissions system (not removed) and temporarily  plugged the vacuum ports.  Battery shows 12.6 volts after a charge and rest.  But now it WON'T START,  starter spins the motor, but it will only fire once or backfire once in several tries.
Tried to remove the carbs last night, but failed...did some more research (thankyou youtube posters) and planned to remove the carbs for cleaning tonight, wish me luck and persistence.
I thought I could at least get it idle poorly and go from there, but no luck.
Any suggestions of where to look would be most appreciated!
Offline scunny
  • don't call me expert
Re: 85 xv1000 virago starting woes.
« Reply #1 on: July 29, 2020, 05:30:38 PM »
Is the fuel pump working ?
wet plugs
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline kerryb
  • Not a very
« Reply #2 on: July 29, 2020, 05:42:26 PM »
Yes, fuel pump is working and will fill the bowls in several seconds.  Bowl level confirmed at 1mm below the seam with clear tube method.  Plugs are pretty new and clean.  They have wet residue on them after several tries at starting.  Tried using the choke with no success.  Fireing and backfire only occur with choke off.
Offline kerryb
  • Not a very
« Reply #3 on: November 09, 2020, 07:07:11 PM »
For those that learn from others mistakes, here's another opportunity.  The bike ran for awhile, then died again.  Culprit turned out to be plug caps and plugs themselves.  The plugs would fire when tested, but a more knowledgeable observer said " look how the spark dances all over the place...that's not right!"
New caps and plugs and the bike runs great now.
