Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Who did you have do the work? I may want to send mine in.
I installed the wheel last winter with only a couple hundred miles on it since. I will check that tonight though. What I read in old threads on here was that the bounce would never be caused b the worm gear at the wheel. If it works at all (which it does 50% of the time) then the mechanism is working at that end.
