Author Topic: Squealing front brake  (Read 628 times)
Offline paulbaker1954
  • I 'll just be 5 minutes dear!!
« on: August 16, 2020, 11:56:06 PM »
Hi from the UK.
My K0 500 four is driving me nuts with the front brake squealing when applying light pressure. No squeal when braking harder.
I have posted on the UK sister site and seems this is just one of those things and they all do it. But my friends doesn’t !!
All is cleaned and adjusted properly and caliper is not stocking etc.
Have just ordered some EBC pads to see if that helps
If you think there's light at the end of the tunnel it's usually another train !!
2014 Triumphy Trophy 1200
1971 Honda CB500 Four K0
Re: Squealing front brake
« Reply #1 on: August 17, 2020, 01:05:20 AM »
Its happening more now asbestos is no longer allowed, making sure all the pivots are free and greased plus piston free and nylon washer between pad and piston, pad free in housing and greased.
Some people have had sucess using a scotchbrite pad to clean the disc surfaces but mostly it comes down to the old adage
"They nearly all do that sir!!"
« Reply #2 on: August 17, 2020, 01:21:52 AM »
 I've heard beveling the edge or cutting slots across the friction material can help. On 70's gm cars we used a graphite core from a d battery, drilled and inserted it into the pad. Probably added to the stopping distance though.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: August 17, 2020, 09:07:25 AM »
My piston was not retracting well which caused some squeal.
It's fixable, I never heard the nylon pad behind the piston trick. I may have to investigate that.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: August 17, 2020, 09:37:29 AM »
Not a nylon pad as such its like a large square section O ring that fits arround the "bump" on the back of the pad, i think its shown in the parts list it was there from new
Online PeWe
« Reply #5 on: August 17, 2020, 12:21:44 PM »
I got a nylon ring with a setup of SBS pads.
Now other that I gave a dollop of copper grease behind the stationary one (inner pad).
Adjust the screw wirh spring on caliper bracket.
The caliper bracket is greased and move easily. It has 2 o-rings to keep grease in place.
Good to service when changing front tire.
And finally, yes despite doing all this it can make high pitch sound now and then. :D
