Author Topic: Keihin CR31 tickler carbs on 750 K head what's needed?  (Read 1125 times)
Offline napoleonb
« on: August 26, 2020, 04:55:26 AM »
Hi guys, a search didn't come up quite with the results I was looking for.
The old Keihin CR31's have a 40mm diameter spigot on which the intake rubbers mount.
Earlier carbs (K1-6) are 37mm whereas K7/F0/F1 might be 40mm but I'm not sure, F2 seems to be 40mm.
K heads have different intake spigots to F2 heads (perhaps also K7/F0/F1) in regards to thread sizes as well as spigot outside diameter
Removing intake spigots seems possible: http://forums.sohc4.net/index.php?topic=115072.0
The rubbers have different lenghts between K/F besides different spigot diameters.
As I understand it the rubbers that belong with the CR31's had the earlier longer length
My K6 head will have some head-work done like porting and a valve job, but i would like to have this sorted before handing the head over.
My options and question are the following:
Option 1, using the standard K6 spigot fitted in the head with early K rubbers means I have to customize my CR31 carbs. But do they fit without altering spacing and only turning down the spigot?
Option 2, turning custom intake spigots with the thread fitting to K heads and the spigot diameter from a F2, using F2 rubbers. Do I have to alter the spacing between the carbs or can I use CR900 instead of CR750?
Option 3, using the standard K6 spigots, standard CR31's and adapting early K rubbers to accept a larger carb is this feasible?
Option 4, ...... ?
« Last Edit: August 26, 2020, 09:38:44 AM by napoleonb »
Offline johno
Re: Keihin CR31 tickler carbs on 750 K head what's needed?
« Reply #1 on: August 26, 2020, 03:53:35 PM »
Hi Napolean,
I have fitted a couple of sets in the early 70's, before the later 40mm spigots came out. All I done was get a sanding drum as close to 37mm as possible ( I think it was 35mm diamanté's drum) then mount the rubbers onto the head,  clamp head to bench , then work away slowly carefully bringing out the 1.5mm required. I remember it was hard to keep it perfect but with new soft rubbers you will be forgiven if its half a mm out.   Slow and steady, takes awhile, bout an hour for 4.
A whole lot easier than dicking around with spigots, they break, crack etc , not the best way that's for sure. Ive also used the grinding drum method to fit other carbs to Honda rubbers, ie RC webber manifolds and Mikuni carbs.
cheers Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline napoleonb
« Reply #2 on: August 31, 2020, 02:53:49 AM »
I have ordered the early K rubbers and will open them up. Will let you guys know how it worked out.
Currently I'm also trying to figure out which felts, o-rings and rubbers are needed in order to revive these carbs.
Offline dragracer
  • CB750F Dragbike
« Reply #3 on: September 01, 2020, 04:20:40 AM »
K7/8 intake rubbers.
