Author Topic: Tachometer cap mutilated  (Read 640 times)
Offline BrickWoll
« on: August 26, 2020, 08:17:08 PM »
In an attempt to remove the tach cable where it attaches to the engine, I hit the cap a bit too hard with a phillips driver and it crumbled.  My concern is whether there is any risk of debris getting into the cylinder.  I have not attempted to pull the cap out yet.  I'm hesitant to move anything until I'm sure nothing can fall back into the hole.
So...
1) Am I good to slide the unit out as is, with the tach gear?
2) Can the whole tach gear be removed and NOT replaced (hole capped)?
Thanks for any advice.
« Last Edit: August 26, 2020, 08:58:40 PM by BrickWoll »
'77 CB550 K3
Re: Tachometer cap mutilated
« Reply #1 on: August 26, 2020, 09:27:54 PM »
Yes it can be capped but need an O ring on the outer diameter of plug, the casting is being remade but it is EXPENSIVE
