SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Felt washer on carb slide actuator pivot arm ? Lost one
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Felt washer on carb slide actuator pivot arm ? Lost one (Read 678 times)
XC204
Enthusiast
on:
April 27, 2020, 06:30:11 PM »
Some how I lost one of the felt washers on the carb slide actuator lever are they available or an alternative or make my own? Thought about. An O ring that is not too tight nor loose.
Thanks
Gary
Logged
1973 CB500 K2
http://forums.sohc4.net/index.php/topic,101767.0.html
my name is nobody
Hot Shot
I like Pontiacs and Hondas
Re: Felt washer on carb slide actuator pivot arm ? Lost one
Reply #1 on:
April 27, 2020, 07:39:09 PM »
Put an ad in the "wanted" section. Someone probably has one from a junk carb
Logged
SF
Hot Shot
I burn gas very well
Reply #2 on:
April 27, 2020, 07:40:29 PM »
The felt washers hold oil to lubricate. Get some punches and order a sample bag of SAE F-1 industrial felt and make your own or some one can chime in with alternatives
Logged
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
XC204
Enthusiast
Reply #3 on:
April 28, 2020, 04:16:00 AM »
Thanks guys
Gary
Logged
1973 CB500 K2
Machine1
Full Member
Reply #4 on:
August 30, 2020, 08:03:38 PM »
I recently replaced all 4 of my felt washers with some made from a gentleman who makes them from this site:
www.dudesgarage.com/
They are a bit of a tight fit, so I just used a little bit of bearing grease on the inside of the felts to get things moving well. also had to vacuum sync again - but let me tell you, my bike has never run so well and so tight. I’m running a 550 with a cognito moto air box filter. It idles like a kitten.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
