Hey team. I know there are lots of discussions on the forum about this, but no 2 cases are ever the exact same, so please indulge me and chime in if you can help.
I have a '74 CB750, and the fork tubes are just shot. I have a line on some forks from an '82 DOHC CB750. The tubes are still 35mm, so should fit in the stock clamps no problem, but is that a swap people have done? I also want to upgrade to a dual disc on the front, so if I can find an '82 front wheel and calipers, then I figure I should be pretty well set.
Is anybody familiar with this idea? Is my logic sound?
I am going to be replacing the master cylinder and lever with an aftermarket capable of pushing dual calipers, so that shouldn't be an issue.
I have attached a picture of the '82 forks.
Thanks in advance for any guidance.
