Author Topic: 1977 CB550K TUBE ASSY., DRAIN 17358-341-000 Replacement?  (Read 914 times)
Offline Maraakate
« on: August 24, 2020, 09:45:35 AM »
Hey everyone, I noticed there is a crack in the tubing for the air box blowby hose at the bottom of the air box on my 77 CB550K.  Honda part number is 17358-341-000 but is NLA.  Normally, I would just get some heater hose for this, but it has that odd bell shape at the top of the hose.  I'm assuming someone out there has found something from a newer model year and trimmed it to fit?  If yes, what part can I order?
The CB550 Assembly Manual stickied in this forum mentions using a longer hose, trimming to length, removing the little foam filter, and finally installing a drain plug.  So I guess this user found some replacement part for it.
I should also mention that I have noticed the actual plenum drain hose by the air intake boots is missing as well.  It appears to be part number 17335-323-000 and I see jtmarks77 has it, but was curious if anyone knew again of a modern replacement part number I can just give to my dealer and cut it to fit.
1977 CB550K
1979 CM400A
Offline Maraakate
Re: 1977 CB550K TUBE ASSY., DRAIN 17358-341-000 Replacement?
« Reply #1 on: August 29, 2020, 10:17:13 PM »
Bump.
1977 CB550K
1979 CM400A
Offline Scott S
« Reply #2 on: August 30, 2020, 02:31:51 AM »
 You can use the same hose on both. Scroll down to the air box section in Ron's thread. He shows how he did it.
http://forums.sohc4.net/index.php/topic,151576.0.html
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
