a short while ago i repacked my kerker megaphone to give the 400 some fresh memories of being new so long ago, and i picked at this site for any pointers on the procedure. any way i didn't get any expert advice so i packed it full instead of a wrap of glass wired around the center perforated tube. i don't think it's a supertrap style. it's just the headers and muffler megaphone with a single cone on the end. the job turned out a heavy muffler, real heavy. and it ran real quiet, but you could tell it was struggling somewhat. ran puny at low end and got better from mid range to w/o, and ran a bit warmer. even started to seep oil around the adjuster caps, hopefully not too much around the cam cover or head, which is about a year old, i never retorqued the head after buttoning it up, only did the series of stages very careful and added a few before even registering on the click wrench, then did it again the next 2 nights., didn't loossen them either just followed the manual. also i didn't go up to the high end of the specs on that. out came the glass, garage door insulation, and i loosely wrapped pieces of a thin later and found some glass crack repair for dry wall, and put a single wrap around the new thin layer, and i didn't pack the cone either. then put a couple of pieces of wire on it, kind of with hopes of some of it blowing out just to get the illegal sound back. right away i could tell, that there needs to be some space in the muffler, it ran cooler, like faster also. so there you have it.
