Author Topic: What wire does this go to??? 75 Cb550F  (Read 1070 times)
Offline CarbasaurusRex
« on: August 31, 2020, 04:29:24 PM »
Not sure if it’s crucial but anyone know? Brown with blue stripe. Found in headlight housing.
Re: What wire does this go to??? 75 Cb550F
« Reply #1 on: August 31, 2020, 04:56:14 PM »
Turn Signal Buzzer
What is a buzzer?? And do you know what wire it attaches to? I don’t see another blue/brown wire
« Reply #2 on: August 31, 2020, 05:44:25 PM »
There should be a "buzzer" beneath the headlight, in front of the coils. It sort of chimes when you activate the indicators. It plugs into the other end of a Blu/Brn wire from that device.
Looks like this:
https://www.cmsnl.com/honda-cb550-four-1975-cb550k0-usa_model465/buzzer-winker_38400341674/#.X02ZFy2z0cg
I’m going aftermarket led signals and aftermarket healdight. I don’t really need it, do i?
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #3 on: August 31, 2020, 09:55:54 PM »
The purpose of the buzzer is to remind you to turn the signals off after use. it can be disconnected without affecting anything else
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: September 01, 2020, 11:34:52 AM »
Just fold the end over and seal with good electrical tape to prevent shorts. You don't need the buzzer and as My Name if Nobody says, disconnecting it doesn't hurt anything.
Offline carnivorous chicken
« Reply #5 on: September 01, 2020, 11:50:01 AM »
Should be, but likely isn't. Many (most?) people remove them as they are annoying as hell. It's one of the first things I do when I get a bike that has them.
The Sovereign Man
« Reply #6 on: September 02, 2020, 12:38:48 AM »
But if you remove the buzzer, how do you get people to stare at you at the traffic lights?
« Reply #7 on: September 02, 2020, 06:22:05 AM »
By leaving your turn signal on for miles and miles because there is no buzzer to tell you to turn it off?
Online Don R
« Reply #8 on: September 02, 2020, 08:35:36 AM »
 I have a 78 goldwing, it's buzzer beeps above 40 mph, below 40 it clicks loudly and at lower speeds it clicks quietly. I like it.  I always thought it was an anomaly, apparently it's a design feature.
 You should find a tab on the inside of the left headlight ear with a square hole, that's where the beeper was.
Offline newday777
« Reply #9 on: September 02, 2020, 10:56:07 AM »
Stu
My current rides
Prior bikes....
